Space 3D
Space 3D
Visits: 1.6K
PBR Substance Material on Character Creator Version 2. Stone, Wall , Road and Landscpace looks good. On iClone 7 ---------> will be very good ( more light, more tool )  --------------------------------------------------------------------------------------- Visit Space 3D Gallery - http://city.reallusion.com/store/space3D
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Thank you Urbanlamb. Like you I don't want realistic texture. Just want coherent things. Animation, facial, behavior lighting but not realistic. There's a difference. My cyclope clown is definitly not realistic but coherent and that's exactly what I need. For toon shader I don't know the futur but may with the open architecture some one will write very cool shader output. I'm very confident with this release :)
Visits: 62.6K
Here's a car thaqt I've been putting some chrome on with CC2 PBR settings.
urbanlamb
urbanlamb
Posts: 1.2K,
Visits: 3.5K
mtakerkart (1/7/2017)
You can mix PBR and Legacy too.  Awesome thank you very much that will produce some very nice things!
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Posts: 15.8K,
Visits: 31.4K
JimmyB7 (1/7/2017) I have CC2 but how do I get CC2 to open instead of CC1? Is there a path or configuration change I need to make somewhere? The attached prop follows the CC avatar into old CC but as you know there is no PBR capability there. I don't have IC7 yet.
Currently, you will have to save the avatar with prop and then import it in CC2. There is no direct path yet (as this is not the release version). EDIT: I just noticed Rampa gave more extensive instructions...:blush:
Visits: 62.6K
To get said car into CC2 from iClone 6:
Add CC 1.5 character into iC6. Add car to scene. Attach car to character. This makes the car an accessory. Save the character to your content library. Open CC2. Drag the character from your iC6 content library into the scene window of CC2.
You can also drag the character in from an Explorer window (or desktop). And lastly, you can use the "File/Open" in CC2 to open any CC character file from its location.
JimmyB7
JimmyB7
Visits: 3.2K
justaviking (1/7/2017)
JimmyB7 (1/7/2017) [quote]rampa (1/7/2017) For anyone who wants to play with texturing props, just attach them to your avatar that you open in CC2. You could even set up a whole scene. The PBR/IBL combo can look really good!Can this be done without IC7? Yes. You should be able to attach a "Classic" prop in iC6, and then bring it into CC2. Once in CC2, you can change the shader to "PBR" and apply a nice metallic material.
CyberpowerPC, 64 GB Ram, 64bit Windows 10 Pro, Intel Core i9-10980XE 18 Core CPU, ASUS TUF X299 Mark 1 Motherboard, ROG-STRIX-RTX2080TI-O11G-GAMING graphics card, Toshiba 3TB hard drive, 3 x Seagate 3TB hard drives, RAGNAROK 801 Full Tower, LEPA G1600 1600W power supply, Killer WI-FI 6, ASUS PA329Q 32" 4K/UHD IPS Monitor.
urbanlamb
urbanlamb
Posts: 1.2K,
Visits: 3.5K
I don't think there will be a problem.
Even in this beta release of CC2, you can pick between "Classic" and "PBR" shaders, and you can do that on a per-object basis. And PBR does not have to mean shiny metal. Turn down the metallic channel, and it's not metal. There will be a bit of a learning curve, but I have a feeling you'll be happy with iC7. oh thank you that makes me feel way better! I like the more "realism" in water/trees and the more cartoony on characters/objects. I had big ideas which it seemed to me that would be possible in the new iclone with some of what I was seeing. Its probably just everyone excited about the new stuff but if i can mix/match or go completely one way or another then this is very good! The advancements in realtime makes it possible for me to do things that I just could not really do before as a retired one man band. I was just kinda waiting for it to happen cause I knew it would with all the game engine advancments it was only a matter of time.
@urbanlamb,
