Tesiras Character Creator 2 Experiences
Posted By Tesira 9 Years Ago
3
4
5
6
7
9
Tesira
Tesira
Posts: 1.3K, Visits: 2.4K
wires, I don't think, that this is only connected with shadow and light. I have changed a lot, without getting a really good result.
All the odd effects I have seen meantime are all connected with .png textures and/or opacity. Maybe there really is an error in the calculations.
brainsguy
brainsguy
Senior Member (288 reputation)Senior Member (288 reputation)Senior Member (288 reputation)Senior Member (288 reputation)Senior Member (288 reputation)Senior Member (288 reputation)Senior Member (288 reputation)Senior Member (288 reputation)Senior Member (288 reputation)
Posts: 24, Visits: 183
Experimenting with metals
1.5 and then 2.0
https://forum.reallusion.com/uploads/images/76a094cf-dcb4-468b-be1d-8891.png
Tesira
Tesira
Well brainsguy, with the metallic also some is very odd.
If I make the metallic parts in in the metallic and roughness channel black, the colors are nearly so how in the texture. The nonmetallic parts are white.
https://forum.reallusion.com/uploads/images/760b420c-d09f-4a3b-a969-6723.png
Here I have inverted the metallic channel:
https://forum.reallusion.com/uploads/images/3c522369-49e7-433d-be25-2daf.png
Here I have inverted the roughness channel:
https://forum.reallusion.com/uploads/images/eee78ec1-f7a2-4c54-8e74-7e44.png
Here are both channels inverted:
https://forum.reallusion.com/uploads/images/1df23c21-4590-49ed-a0c3-a913.png
Here  the metallic channel is fully white:
https://forum.reallusion.com/uploads/images/1d2584f1-a3fb-40b9-9220-d32a.png
Also a bug - the brightness -100 dos give white and 100 dos give black.
Have a nice day
Tesira
Tesira
Tesira
Meantime I have seen, that this dos happen with the brightness -100 ->white texture and 100 (black) only, if the texture is inverted. So maybe not a bug, but confusing.
Here we go fully metallic with a black texture in the roughness channel and a white in the metallic.
https://forum.reallusion.com/uploads/images/a73e434d-52df-4be0-a740-2545.png
Posts: 8.2K, Visits: 26.5K
Yes, "all metal" with "zero roughness" should be extremely shiny.
No roughness = total smoothness
It really should be "zero" rather than "-100."
brainsguy
brainsguy
Sorry my post wasn't supposed to be here. I thought I was posting in one of the other topics.
Tesira
Tesira
Yes justaving.
You are welcome brainsguy, so I also have delt a bit more with metallic :)
Here I have worn the pirate lady to my little girl. It fits well, So cool.
https://forum.reallusion.com/uploads/images/5afdfe55-6003-4f58-ac3d-77b7.png
Only the gloves are to small.
https://forum.reallusion.com/uploads/images/915f2c6d-ce72-4104-9465-4b47.png
And I have problems with conform. There happen odd things. Here the result of increasing the gloves:
https://forum.reallusion.com/uploads/images/106f426b-7921-4b4e-96b8-ae55.png
But this dos not work always in the same way. Sometime the effect is haevy, sometime it dos work a bit, how it should.
Sometime it dos already happen, if I click with the mouse at the gloves.
So it is hard to find the reason for this.
Have a nice day
Tesira
Posts: 8.2K, Visits: 62.5K
What a great pirate costume for your little girl Tesira! :)
There might be some displacement on the glove material. That would cause that. I usually hide the body mesh if it is fully hidden by clothing. You use the mesh edit tool to select and hide parts of the mesh.
Tesira
Tesira
Well rampa, the gloves were really fully deformed after this effect. There also the hide mesh would not help. We seems to have here really a bug.
Here we have worn the next outfit.
The shoes were much to great and also conform hasn't helped.
So I have used the mesh editor, this has worked well.
With this character also the appearance editor has loaded fast and has done, what he should.
I only have had problems with the nails. Nothing has worked, I have 5 times tried, to change the color. But suddenly all was ok.
So again hard to say, what was here the problem.
https://forum.reallusion.com/uploads/images/19227628-c15a-4ef3-ad4a-fbf8.png
Have a nice day
Tesira
I've had problems scaling outfits before. Especially shoes.
3
4
5
6
7
9
