AirBeagle1
AirBeagle1
Last Active: 8 Years Ago
Visits: 33
Posts: 15.8K,
Visits: 31.3K
I am not on a Mac, but if you have a video editor that can handle image sequences, you could try the following: set the background to black and export as a PNG image sequence. This will give you the model against a transparent background. This works with the 3D head model. I tried the same with the 2D model, but I had no success.
AirBeagle1
AirBeagle1
Visits: 33
Thanks Lernakow! I played around with this some more through the night and it looks like that default gray background does export for 3D models, even with Apple ProRes4444, though you can get the transparent background with 2D Models in CT8. Not sure why that is, or if I'm missing something, but I'm thinking you may be right in that it will be much simpler in the long run to just export with an obnoxious opaque background and key it out later in my video software. You assistance has been MUCH appreciated! I'm looking forward to sharing my first CT8 project with my students (and of course will post here as well). Make it a great day!
Lernakow
Lernakow
Visits: 770
There is no background in a new project. You can add it and then probably remove it (I never tried removing), but at first you have no background other than the light grey application background that is not included in the export (opaque formats make it black, transparent format makes it transparent (although if you just play it in QuickTime it will look black). You only see that the result is transparent if you import it to your editing application and lay it on top of something else. On the other hand transparent export is very slow. I'm wondering if it wouldn't be more effective to use a green box and then remove it in editing with chroma keying.
AirBeagle1
AirBeagle1
Visits: 33
Just a quick follow-up. You mentioned exporting in Apple ProRes4444 to allow for a transparent background. I'm exporting in ProRes4444, but I haven't figured out how to switch to a transparent (or no) background in CrazyTalk 8. I could make the background something obnoxious and bright and then key it out later in Final Cut Pro, but the workflow seems cleaner if there's no background there to begin with. Thanks for any tips/advice! Make it a great day!
AirBeagle1
AirBeagle1
Visits: 33
Thank you Lernakow... really appreciate your patience and time as you help out a newbie. Make it a great day!
Lernakow
Lernakow
Visits: 770
You can get short male hair as a texture not a 3D model. When you create a head from the pictures one of the last steps is the texture selection - it varies from face only (with bald head) to full head (with whatever hair it originally has). With full head you get the original hair of the model. You can only get very short hair or hair that lay flat on the head (like combed back in a ponytail but without the tail). On male characters it looks rather good in my opinion. I believe you can also change the texture into the hairy one in existing models (from 100 heads), but I'm not sure and I won't get to my CrazTalk computer before evening (CET) to verify.
AirBeagle1
AirBeagle1
Visits: 33
So I'm up and running... have installed CT8 Pipeline with RealHuman100 and the Dress Show, as well as CTA3 for some future work. Starting to get the hang of this as I go through the various tutorials, but I'm definitely stuck in one big area as I try to create a reasonable 3D model... the male hair. I haven't been able to find reasonable male hair that isn't completely wacky, even with the RealHuman100, Dress Up - Showtime, and various bonus packs. Does anyone have recommendations for a fairly standard business-ish type hairstyle to place on the character? Looks like there are a number of female hair styles with longer hair that would be reasonable acceptable, but pretty slim pickings on the male side.
Looks like I have a ton to learn, but a fun new challenge!
AirBeagle1
AirBeagle1
Visits: 33
Thanks Cricky. Mostly I'm interested in replacing my torso in the bottom right of the video with something animated (which also provides an opportunity to work around the many times in the videos when I'm looking down at the screen as I write). The chalkboard idea is pretty cool, I think, but might be a bit more work on the animation side than I want to engage in at this point, vs. focusing on the educational content -- and iClone looks really cool, though I find I try to avoid Windows apps on my Mac, though I do use Windows apps on rare occasions when forced. Neat ideas, though.
CTA3 also had me thinking about all the other things that I could do to improve these lessons -- objects and demonstrations I could add in (such as animating the angular momentum question a bit). I have access to the Adobe CS at the moment, and though CTA3 looks like it might make some of the animations I'd want to try easier, I'm not sure the price and learning curve would be worth the additional added benefit.
Fantastic advice, though, and now these great responses have me thinking beyond just what could I do with CrazyTalk 8... gotta finish my current project and start playing around. Thanks for all the input!
Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
AirBeagle1 (12/9/2016)
Hi! I'm a high school science teacher with a question about what the right product is for my needs, and am hoping to lean on the experience of this fine group of experts. I create short educational videos for my students (and others) that I post on YouTube. These videos currently include my profile in a corner of the video, while the students see the work I'm doing in the main section of the video (example here: https://youtu.be/LlD0zy9XGl4 ). What I think would be really cool would be to replace my video image with an animated avatar that talks with my voice. The big question -- I'm having a heck of a time figuring out exactly which product (or products) here would best suit my needs, or if I'm even in the right place. I work on a Mac platform, and would love any advice you might be willing to share. Thanks Much! Your link to YouTube embedded below will help people see what you are referring to.Regarding what you want to do; You can use CrazyTalk, but you can also use iClone to do what you want. Create a Head that looks like you for iClone use, apply it to an existing Character/Avatar and apply scripted facial animation plus body motion if desired to allow you to point to specific items while talking, or even hold up prop "Cue Cards". The Character Video can be exported using Alpha Channel options and overlaid in the corner of a video (using your sample as a demonstration of what you desire to achieve). Using the upper body as well as the head will allow you to be more expressive in your presentation. You may even want to consider using CrazyTalk Animator (CTA) for using the entire Body or just the upper; it all depends, of course, on the route you want to take. Using pre-recorded script would allow you to look (simulated) at anything in the scene behind you, including the audience, and not be obviously reading Cue Cards, which would be what I suspect your intent is. Do not use any background for iClone, and the Alpha Channel is much easier to achieve. Using a contrasting color (Green Screening) as a background color makes the separation of the Avatar and background easier. Even if you decide to not using Alpha renderings you can use the output as an overlay if your video editor has the option to extract using Alpha Masking, which I use frequently in post video editing. You could also use a Chalkboard or Projection Screen to write on if you like. I do have both in the Marketplace shown in my signature links and directly linked by name. If nothing else it could be used to spell out your name in scripted text as an introduction to the subject and yourself. I do not use MAC versions of the software, but I understand that there are versions or workarounds for those that do.
SKYPE ID: rc.650
