World machine terrain compatibility in Iclone
Posted By IO1 10 Years Ago
3
mtakerkart
mtakerkart
Posts: 3.2K, Visits: 29.2K
Cool!! Thank you Rampa :)
Posts: 8.2K, Visits: 62.6K
Urbanlamb made one. I keep a copy on my Google Drive. It uses the traditional shader, but has inputs for bump maps and other goodies as well.
https://drive.google.com/open?id=0B3nsNVGroEz6YTFsY1pldHdwOG8
The colors for the map cannot be mixed/blended, so you will have hard edges on the materials. Make sure that there is no color mixing from anti-aliasing or anything, because it will cause artifacts.
mtakerkart
mtakerkart
About this "substance " Rampa , do you know if some one has created a 7 color substance (like in CC) that we can use on the prop terrain.
Painting the textures aeras in photoshop with Black , red, yellow , green, etc.... Then reassign the true texture in Iclone.
I tried to look inside Substance designer but give up because  of the very hermetic philosophy...:ermm:
I think it is also worth pointing out that if you use meshes instead of the heightmap, you can use Substance materials and displacement. Using tesselation and displacement, you can add all sorts of new detail that will be a magnitude higher than the actual mesh resolution.
Jfrog
Jfrog
Posts: 702, Visits: 4.7K
Really nice!  Thank you for the tips and infos.
Horror Stories in VR
Immersive Sound VR
mtakerkart
mtakerkart
@Animagic  Thank you !
The poping desapear when rendering in Final render-super sampling , not in a preview mode.
You can disable LOD in the preferences if you don't want the jumps in detail. It looks better with it off.
https://forum.reallusion.com/uploads/images/57ec7729-c610-4d4f-8f2a-cf02.jpg
Posts: 15.8K, Visits: 31.4K
Nice terrain work.
As to LOD: I always get an LOD pop with trees and sometimes with shadows too.
mtakerkart
mtakerkart
You can have same resolution with IC 6 and there is no LOD pop too.
https://forum.reallusion.com/uploads/images/77f28a30-fe91-4585-9a75-bc12.jpg
Yes it's IC7.And I love Earthsculptor , I have the paid version but the free version is enough for my need. I only use it for carving and assign texture area. All of the Textures work is done
in Iclone. There is 3 good Reallusion tutorial about it. But today we need only the texture the export plugin is useless.
https://forum.reallusion.com/uploads/images/9ff6c352-ef55-4df0-a2b9-3592.jpg
Jfrog
Jfrog
Thank you for the nice movie and tips mTakerKart.  4k is so nice when it is not split between 6 cameras.  I never rendered anything but VR360, so I always have around 700 pixel of resolution at 4k.
Was this rendered in Iclone 7? It looks very nice. Your mid shot cottages seems to have great resolution too. If you don't mind asking, do you like earth sculptor?
I read a bit about it but I think there is no 64 bit version of the software isn't it?
Thank you.
Immersive Sound VR
3
