Separating the hair from the head/fave sprite
Posted By ramuse1970 10 Years Ago
kylelee
kylelee
Posts: 462, Visits: 4.2K
In CTA3.2, you could use Accessory to modify this issue. (Please refer Online Manual)
https://forum.reallusion.com/uploads/images/f57f7b4c-5af4-4fa3-8e45-acbb.png
parisgranville
parisgranville
Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)
Posts: 35, Visits: 283
I currently have this problem with CTA 3
toonsunlimited
toonsunlimited
Posted 10 Years Ago
Distinguished Member (4.8K reputation)Distinguished Member (4.8K reputation)Distinguished Member (4.8K reputation)Distinguished Member (4.8K reputation)Distinguished Member (4.8K reputation)Distinguished Member (4.8K reputation)Distinguished Member (4.8K reputation)Distinguished Member (4.8K reputation)Distinguished Member (4.8K reputation)
Last Active: 7 Years Ago
Posts: 341, Visits: 4.3K
Greeting Ramuse1970,
You may not have a layering issue, it could be a joint mask issue.  If you have adjust back hair sprite to be on the bottom layer of the face, but it looks like it's in front of the neck, then try to adjust the joint mask for the neck instead.
Janell
                    https://forum.reallusion.com/uploads/images/c09b5311-3ab1-47a8-995d-c2df.png
https://forum.reallusion.com/uploads/images/0a076bbd-c788-40a3-b65c-4995.png
Sign Up for our Newsletter and Receive10% Off Your First Order!
Website: www.toonsunlimited.com
Email: askjanell@toonsunlimited.com
  Check Out My Channel For CTA "How To" Tutorials
  Follow me on Facebook for Characters in Development
https://forum.reallusion.com/uploads/images/7e3e974d-b57b-4b3a-b000-da9f.png
ramuse1970
ramuse1970
Posted 10 Years Ago
Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)
Posts: 68, Visits: 157
Is there a way to make the back hair of a character behave separately from the head/face as it's own layer?
It seems that the back hair is always in front of the neck when it hangs down below the head/face sprite!
I cannot see any way to correct this.
In the sprite editor you can only move the neck in front of or behind the head/face, but not the hair it's self.
The neck should be in front of the back hair while at the same time being behind the head/face.
Does anyone know a work around for this?
