dobro999
dobro999
Visits: 26
Thank you I will try those. Regards Brian
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
oh in 3D settings try turning off antialiasing too, you can do it just for CC under programs I just recalled I have to do that For DAZ studio
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
Uninstall it and run CCleaner back up and fix the registry too. Safer than mucking around in regedit Make sure you reboot inbetween then do a clean reinstall A clean reinstall of your graphics driver not a bad idea either I have not gotten that error but from time to time have had software stop running esp Reallusion products and this fixes it.
redrubyslippers
redrubyslippers
Visits: 1.1K
i take it you gave googled it, had a look theres a shed load of stuff about it with various fixes some work some do not, if all else fails reformat your pc,, you using windows 10 o r8/7...... and amd or intel graphics, have you tried deleting the entries in the registry as well.
see below
RRS
Alien Maniac
Alien Maniac
Visits: 2.1K
HI Dobro Wow thaaaat is weeeird. All I can even suggest is to do the following: I am blind to your system info so 1. click on your GPU icon (task bar?) click Open Nvidia control panel 2. Open your control panel> see the left menu>manage 3d settings? 3. click it and you will see a box> GLOBAL Settings/Program settings 4. Click on Program settings :::see them all and choose one or add a new program not listed. 5. NOW the fun starts> All of your 3d programs are listed there so choose one and set it> CUDA= Your 3d card....NOTE: You will see 2 menus> Feature and Setting> click on the right side menu settings and then make the correct setting show and SAVE IT. NEXT: Rt click on your program IC (or others) select advanced> RUN AS ADMIN AND SAVE IT.
TRY THIS and if it does not work still> I have no clue. Start a support ticket. I hope it works for you.
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
dobro999
dobro999
Visits: 26
Hi All, I am fairly new to 3D animation, and I am having a frustrating problem . . . When I try and run Character Creator I get the error "Application has been blocked from accessing graphics hardware". I have had this error since I obtained the programme and am still getting it with v1.5. I have no problem running iClone v6.5 (or have ever had a problem with that). I am becoming more desperate to use the Character Creator, so I would be very grateful for any help anybody can give. Regards Brian
