By dobro999 - 10 Years Ago
Hi All,
I am fairly new to 3D animation, and I am having a frustrating problem . . . When I try and run Character Creator I get the error "Application has been blocked from accessing graphics hardware". I have had this error since I obtained the programme and am still getting it with v1.5. I have no problem running iClone v6.5 (or have ever had a problem with that). I am becoming more desperate to use the Character Creator, so I would be very grateful for any help anybody can give.
Regards Brian
By Alien Maniac - 10 Years Ago
HI Dobro Wow thaaaat is weeeird. All I can even suggest is to do the following: I am blind to your system info so 1. click on your GPU icon (task bar?) click Open Nvidia control panel 2. Open your control panel> see the left menu>manage 3d settings? 3. click it and you will see a box> GLOBAL Settings/Program settings 4. Click on Program settings :::see them all and choose one or add a new program not listed. 5. NOW the fun starts> All of your 3d programs are listed there so choose one and set it> CUDA= Your 3d card....NOTE: You will see 2 menus> Feature and Setting> click on the right side menu settings and then make the correct setting show and SAVE IT. NEXT: Rt click on your program IC (or others) select advanced> RUN AS ADMIN AND SAVE IT.
TRY THIS and if it does not work still> I have no clue. Start a support ticket. I hope it works for you.
By redrubyslippers - 10 Years Ago
i take it you gave googled it, had a look theres a shed load of stuff about it with various fixes some work some do not, if all else fails reformat your pc,, you using windows 10 o r8/7...... and amd or intel graphics, have you tried deleting the entries in the registry as well.
see below
By wendyluvscatz - 10 Years Ago
Uninstall it and run CCleaner back up and fix the registry too. Safer than mucking around in regedit Make sure you reboot inbetween then do a clean reinstall A clean reinstall of your graphics driver not a bad idea either I have not gotten that error but from time to time have had software stop running esp Reallusion products and this fixes it.
oh in 3D settings try turning off antialiasing too, you can do it just for CC under programs I just recalled I have to do that For DAZ studio
Thank you I will try those. Regards Brian
