Simple Bodysuit With Blender Tutorial
Posted By Rampa 10 Years Ago
Rated 5 stars based on 4 votes.
Posted 10 Years Ago
Posts: 8.2K, Visits: 62.6K
Threaded View
Threaded View
Forum Post Simple Bodysuit With Blender Tutorial By Rampa ( 10 Years Ago )
Forum Post Thanks, Rampa! Vey easy to follow and instructive. By animagic ( 10 Years Ago )
Forum Post Here's some basic settings I always set in Blender that make it much... By Rampa ( 10 Years Ago )
Forum Post Thanks, rampa. Just what I need...straight to the point and "easy" to... By sjonesdc ( 10 Years Ago )
Forum Post Excellent stuff. Thanks a lot! By majorlance ( 10 Years Ago )
Forum Post [quote][b]rampa (7/22/2016)[/b][hr]... By sjonesdc ( 10 Years Ago )
Forum Post Direct and to the point, as others have stated. Love this format. By sumthinwong ( 10 Years Ago )
Forum Post alle Rampa, thjankls für this TUT, and this is my result Greets from... By Postfrosch ( 10 Years Ago )
Forum Post You beat me to it. You magnificent b******. By Emerald Animation (formerly reelcheapfilms) ( 10 Years Ago )
Forum Post We can expect movies with very tight clothing...:blush: By animagic ( 10 Years Ago )
Forum Post [quote][b]rampa (7/22/2016)[/b][hr]... By Pollux ( 10 Years Ago )
Forum Post Great job! :) By Matt GH ( 10 Years Ago )
Forum Post If anyone needs the free templates and keys, they are available from... By Rampa ( 10 Years Ago )
Forum Post Thanks Rampa for sharing the tutorial. This should really help a lot... By Peter (RL) ( 10 Years Ago )
Forum Post Looks easy enough to learn but I haven't it tried yet, to be honest... By Snarp Farkle ( 10 Years Ago )
Forum Post [quote][b]Snarp Farkle (7/25/2016)[/b][hr]Looks easy enough to learn... By Rampa ( 10 Years Ago )
Forum Post Thanks rampa, I see now that it can be done but 3dmax tuts don't help... By Snarp Farkle ( 10 Years Ago )
Forum Post [quote][b]Snarp Farkle (7/25/2016)[/b][hr]Thanks rampa, I see now... By Rampa ( 10 Years Ago )
Forum Post [quote] rampa (7/25/2016) Like Bud said. Use the DAZ presets he... By Snarp Farkle ( 10 Years Ago )
Forum Post [quote]I've tried for 7 hours to wrap my brain around this seemingly... By Rampa ( 10 Years Ago )
Forum Post Brilliant tutorial, Rampa. Liked the easy to follow steps. Thanks for... By Walt_R ( 10 Years Ago )
Forum Post Here is a tutorial for quickly finishing the cuffs of the bodysuit. I... By Rampa ( 10 Years Ago )
Forum Post @Snarp Farkle & Rampa, Exactly the same size thing happens to G3-G5... By wires ( 10 Years Ago )
Forum Post Hi Rampa, The tutorial is great, but I can't get past the Create... By TopOneTone ( 10 Years Ago )
Forum Post [quote][b]TopOneTone (7/26/2016)[/b][hr]Hi Rampa, The tutorial is... By Rampa ( 10 Years Ago )
Forum Post Yes I did that step each time. Could it be to do with preferences in... By TopOneTone ( 10 Years Ago )
Forum Post [quote][b]TopOneTone (7/26/2016)[/b][hr]Yes I did that step each time.... By Rampa ( 10 Years Ago )
Forum Post Hi Rampa, Your fbx worked fine in my CC, but when I loaded your file... By TopOneTone ( 10 Years Ago )
Forum Post [quote][b]TopOneTone (7/27/2016)[/b][hr] Hi Rampa, Your fbx worked... By Rampa ( 10 Years Ago )
Forum Post Are you making the armature visible again to see those bones? When I... By TopOneTone ( 10 Years Ago )
Forum Post [quote][b]TopOneTone (7/27/2016)[/b][hr]Are you making the armature... By Rampa ( 10 Years Ago )
Forum Post I imported the RL base, did nothing to it, then exported, brought into... By TopOneTone ( 10 Years Ago )
Forum Post [quote][b]TopOneTone (7/27/2016)[/b][hr]I imported the RL base, did... By Rampa ( 10 Years Ago )
Forum Post @rampa: What version of Blender are you using? I'm using 2.77a By blackhawk ( 10 Years Ago )
Forum Post [quote][b]blackhawk (7/27/2016)[/b][hr]@rampa: What version of Blender... By Rampa ( 10 Years Ago )
Forum Post Sorry to be a nuisance with this, but it looks like the problem is... By TopOneTone ( 10 Years Ago )
Forum Post [quote][b]TopOneTone (7/28/2016)[/b][hr]Sorry to be a nuisance with... By Rampa ( 10 Years Ago )
Forum Post I tried to send you a 3mb zip file but in Add File it says I have... By TopOneTone ( 10 Years Ago )
Forum Post [quote][b]TopOneTone (7/29/2016)[/b][hr] I tried to send you a 3mb zip... By Rampa ( 10 Years Ago )
Forum Post Thanks Rampa for all your help in getting me past this problem. Your... By TopOneTone ( 10 Years Ago )
Forum Post Well I have managed to finally get this workflow to work on my Windows... By blackhawk ( 10 Years Ago )
Forum Post @snarp and rampa i import this at 0.40 scale in max, isn't there some... By Skuzzlebutt ( 10 Years Ago )
Forum Post [quote][b]budbundy (7/26/2016)[/b][hr] @snarp and rampa i import this... By wires ( 10 Years Ago )
Forum Post [quote][b]wires (7/26/2016)[/b][hr][quote][b]budbundy... By Skuzzlebutt ( 10 Years Ago )
Forum Post [quote][b]wires (7/26/2016)[/b][hr][quote][b]budbundy... By Snarp Farkle ( 10 Years Ago )
Forum Post You really should not scale the avatar. Unless, of course, you want a... By Rampa ( 10 Years Ago )
Forum Post @snarp, do not scale the avatar..... in the daz advanced export... By Skuzzlebutt ( 10 Years Ago )
Forum Post [quote][b]budbundy (7/26/2016)[/b][hr]@snarp, do not scale the... By Snarp Farkle ( 10 Years Ago )
Forum Post [quote][b]Snarp Farkle (7/27/2016)[/b][hr][quote][b]budbundy... By Skuzzlebutt ( 10 Years Ago )
Forum Post Has anyone figured out a workflow with zBrush and Blender to do this? By blackhawk ( 10 Years Ago )
Forum Post need help the cloth, hair, acc menu is missing for me, how do you fix... By markdsab ( 10 Years Ago )
Forum Post [quote][b]markdsab (8/4/2016)[/b][hr]need help the cloth, hair, acc... By wires ( 10 Years Ago )
Forum Post Yes, I forgot to update...Thanks! By markdsab ( 10 Years Ago )
Forum Post Every time I export to .fbx Blender crashes and the toggle system... By markdsab ( 10 Years Ago )
Forum Post Finally had time to work through the tutorial, did a little... By sjonesdc ( 10 Years Ago )
Forum Post It does not work for me. I have followed these instructions a dozen... By toppro77 ( 10 Years Ago )
Forum Post [quote][b]rampa (7/22/2016)[/b][hr]... By toppro77 ( 10 Years Ago )
Forum Post [quote][b]toppro77 (8/7/2016)[/b][hr][quote][b]rampa... By toppro77 ( 10 Years Ago )
Forum Post [quote][b]toppro77 (8/7/2016)[/b][hr] [quote][b]toppro77... By Skuzzlebutt ( 10 Years Ago )
Forum Post I have also had issues with CC crashing when I try to bring in the fbx... By Cary B ( 10 Years Ago )
Forum Post [quote][b]Shadoesword (8/25/2016)[/b][hr]I have also had issues with... By Rampa ( 10 Years Ago )
Forum Post Thanks Rampa. I now have another question about Character Creator,... By Cary B ( 10 Years Ago )
Forum Post I have followed the Bodysuit tutorial and was able to reproduce the... By Lord Ashes ( 10 Years Ago )
Forum Post Just checked and updated my Blender version. The new version does show... By Cary B ( 10 Years Ago )
Forum Post The new version version of Blender seems to have solved my crashing... By Cary B ( 10 Years Ago )
Forum Post You need to parent with empty groups instead, and then transfer the... By Rampa ( 10 Years Ago )
Forum Post Thanks for the quick reply. I will review the provided tutorial and... By Lord Ashes ( 10 Years Ago )
Forum Post I have followed the tutorial but when I get to the Transfer Weights my... By Lord Ashes ( 10 Years Ago )
Forum Post Your getting really close! :) By Rampa ( 10 Years Ago )
Forum Post Hi, Thanks for the great info. I have successfully created the body... By ryanmm ( 7 Years Ago )
