Last Active: 4 hours ago
Posts: 15.6K,
Visits: 30.3K
wildstar (7/17/2016) i want know about the dev team if a compability with from iclone alembic and max 2016 will be implemented
Alembic is neutral as to the application, so if the Max alembic implementation is correct it should work. I have tried with a variety of programs without problems.
Posts: 5.7K,
Visits: 26.4K
RL have posted on the Feedback Tracker that they cannot reproduce the watermark issue. I have posted a short screen capture demonstrating this problem, and sent them the project file used to test.
BiggsTrek
BiggsTrek
Visits: 11.9K
wires (7/18/2016) RL have posted on the Feedback Tracker that they cannot reproduce the watermark issue.
We have devs like that where I work. Strikes me that they didn't try very hard and took the easy path (put it back on the user to prove). Hopefully your evidence will suffice and they can finally fix this EXTREMELY ANNOYING BUG.
https://marketplace.reallusion.com/iclone/author/biggstrek
Alien Maniac
Alien Maniac
Visits: 2.1K
LOL really?????? If RL can not find the same problem that we are all experiencing with the undo button......they just need to use IC 6.5 on any PC. LOL or Apparently all of us MUST have a corrupted download of IC 6.5 Has anyone tried to uninstall IC 6.5 and re-download and reinstall it? Just curious.
I have also found that the spotlight rotate does not work correctly. Can anyone verify this?
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
mark
Posts: 4.8K,
Visits: 16.4K
I just tried the Spotlight rotate and seems to work fine here. I have also been trying the last few days, with many different projects and assets bought and built, and I can't seem to duplicate the UNDO problem either. Sorry...I just hate these problems that can't be replicated by everybody but so far I'm having no problem with UNDO and I've tried every-which-way I think ?
Alien Maniac
Alien Maniac
Visits: 2.1K
UPDATE: 6.5.3111 OK, I uninstalled IC>. Rebooted I redoownloaded IC from my inventory. (NO patches) (was 6.5.3111) I installed IC>setup 3d settings for Nvidia and set to run as Administrator I rebooted
NOW: The same exact problem is still there. Watermarks on UNDO
I have 2 copies if IC on 2 computers. BOTH do the same Watermarks on Undo.
Posts: 22.6K,
Visits: 35.6K
wires (7/18/2016) RL have posted on the Feedback Tracker that they cannot reproduce the watermark issue. I have posted a short screen capture demonstrating this problem, and sent them the project file used to test.Hi Gerry, Thanks for supplying the video and project. We are urgently looking into this issue. As soon as I have more news about a fix I will update again to let you all know. Apologies for the inconvenience this issue is causing.
8 Years Ago by
wildstar
wildstar
Posts: 1.2K,
Visits: 5.1K
The New function Lip Options implemented in Iclone 6.42 . dont export to fbx by collect clip function i post here cause i think is a important issue, i believe this issue comes from 6.42 version and no one knows.
8 Years Ago by
wildstar
Posts: 15.6K,
Visits: 30.3K
wildstar (7/19/2016) The New function Lip Options implemented in Iclone 6.42 . dont export to fbx by collect clip function i post here cause i think is a important issue, i believe this issue comes from 6.42 version and no one knows.Do you save the Collect Clip as MotionPlus? That is required for facial animation.
Gerskey
Gerskey
Visits: 1.3K
Hi Peter, when I drop and drag an image into Iclone as background or as a billboard it's upside down? Peace Gerskey
