theschemer
theschemer
Posted 10 Years Ago
Posts: 1.4K,
Visits: 2.9K
Watermarks on UNDO. Argghh. Added vote to the tracker. There are only 8 votes there and I would imagine there are more than 8 people with this issue. Add your vote here: CLICK HERE TO ADD YOUR VOTETS
wildstar
wildstar
Posted 10 Years Ago
Posts: 1.2K,
Visits: 5.1K
animagic (7/19/2016)
wildstar (7/19/2016) The New function Lip Options implemented in Iclone 6.42 . dont export to fbx by collect clip function i post here cause i think is a important issue, i believe this issue comes from 6.42 version and no one knows.Do you save the Collect Clip as MotionPlus? That is required for facial animation. sure i do, the lip options information like smoth, dont go to fbx, so if you plan use your animation outside iclone dont use that or will get a bad surprise like me
wildstar
wildstar
Posted 10 Years Ago
Posts: 1.2K,
Visits: 5.1K
yep, all info goes to FBX but lip options not, so if you plan use your animation with lyp sinc outside iclone dont use lip options or will get a bad surprise
Posted 10 Years Ago
Posts: 5.7K,
Gerskey (7/19/2016) Hi Peter, when I drop and drag an image into Iclone as background or as a billboard it's upside down? Peace GerskeyI just tried this using both jpg and png photos, all came in to iClone without any problems.
Gerskey
Gerskey
Posted 10 Years Ago
Visits: 1.3K
Posted 10 Years Ago
Posts: 15.8K,
Visits: 31.4K
wildstar
wildstar
Posted 10 Years Ago
Posts: 1.2K,
Visits: 5.1K
Posted 10 Years Ago
Posts: 23.1K,
Visits: 36.6K
wires (7/18/2016) RL have posted on the Feedback Tracker that they cannot reproduce the watermark issue. I have posted a short screen capture demonstrating this problem, and sent them the project file used to test.Hi Gerry, Thanks for supplying the video and project. We are urgently looking into this issue. As soon as I have more news about a fix I will update again to let you all know. Apologies for the inconvenience this issue is causing.
Alien Maniac
Alien Maniac
Posted 10 Years Ago
Visits: 2.1K
UPDATE: 6.5.3111 OK, I uninstalled IC>. Rebooted I redoownloaded IC from my inventory. (NO patches) (was 6.5.3111) I installed IC>setup 3d settings for Nvidia and set to run as Administrator I rebooted
NOW: The same exact problem is still there. Watermarks on UNDO
I have 2 copies if IC on 2 computers. BOTH do the same Watermarks on Undo.
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
mark
Posts: 4.9K,
Visits: 16.7K
I just tried the Spotlight rotate and seems to work fine here. I have also been trying the last few days, with many different projects and assets bought and built, and I can't seem to duplicate the UNDO problem either. Sorry...I just hate these problems that can't be replicated by everybody but so far I'm having no problem with UNDO and I've tried every-which-way I think ?
