Alien Maniac
Alien Maniac
Posted 10 Years Ago
Visits: 2.1K
YEA! I got one of my computers to run IC6.5 and no watermarks. I either just got lucky or this was the problem somehow........
I had Malwarebytes on it and the subscription expired so I un-installed it. NOW IC 6.5 works fine and NO WATERMARKS.
BUT> On my other machine> I will check that one today.
So can an AV or Malware program somehow be causing this problem?
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
BiggsTrek
BiggsTrek
Posted 10 Years Ago
Last Active: 6 Months Ago
Visits: 12.3K
wires (7/20/2016) @BiggsTrek,
A rollback would be a royal PITA if it needs to be done. You would need to uninstall iClone, 3DXchange and Character Creator as files from the newer versions will not work with an earlier version. Then you need to make sure that the registry is wiped clean before a full reinstall. You also have to reinstall the previous iClone Resource Pack as some of the stuff in the latest one also won't work with the last version.
I may have to do this myself, but I'm still hoping that it won't be necessary.
The word "yuck" comes to mind. Let's hope for a fix soon. I'm giving them 'til the weekend before I attempt any sort of rollback (was hoping Peter might supply a patch file to revert the changes without the hassle of uninstalling/reinstalling. Think they've done that before...) :-/
 https://marketplace.reallusion.com/iclone/author/biggstrek
Posted 10 Years Ago
Posts: 5.7K,
@BiggsTrek, A rollback would be a royal PITA if it needs to be done. You would need to uninstall iClone, 3DXchange and Character Creator as files from the newer versions will not work with an earlier version. Then you need to make sure that the registry is wiped clean before a full reinstall. You also have to reinstall the previous iClone Resource Pack as some of the stuff in the latest one also won't work with the last version. I may have to do this myself, but I'm still hoping that it won't be necessary.
BiggsTrek
BiggsTrek
Posted 10 Years Ago
Visits: 12.3K
Peter, I'd like a means to roll back to the previous version of iClone. Clearly this one is having issues that affects many of your users. I myself cannot continue production of my movie with this UNDO problem. Thank you.
GIM
Visits: 7.4K
My iClone 6.5 install would not even load with latest 3DExchange trial loaded. I'd double click the iClone 6 icon and nothing would happen. iClone would not be in the task manager either. I had to uninstall 3DExchange to get iClone back working. MT
Posted 10 Years Ago
Posts: 5.7K,
Peter (RL) (7/19/2016) For those experiencing the Undo > Watermark issue, can you try running "Content - 1 Click Verification" (be warned it might take a long time). In addition can you let us know if the projects affected are stored in your iClone Custom Projects folder or are they saved elsewhere on your computer such as the Desktop?. Thanks.My project files are all stored in the iClone Custom folder. The file that I sent for testing was created and saved in iClone 5. Having had my PC blocked once for almost 6 hours while doing a 1 Click Verification I point blank refuse to do it again. The watermark problem has been caused by Reallusion, and they should provide a solution to it that does not cause me even one second of inconvenience. This problem did not exist in iClone 6.4.
planetstardragon
planetstardragon
Posted 10 Years Ago
Posts: 11.5K,
Visits: 46.0K
i'm trying to load an apple pro res movie into iclone - not working, it's a huge file - i have the pro res codec installed - https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Windows and 16 gigs of ram, so I should be ok ....I was able to convert the file in Popvideoconvertor 2 - so the codec is working fine. The only thing I can imagine is that iclone is trying to load this huge file to vram.
wendyluvscatz
wendyluvscatz
Posted 10 Years Ago
Last Active: 4 Months Ago
Posts: 2.5K,
Visits: 19.4K
my mp4 and mov files always load upsidedown been all versions of iClone, nothing new but a PITA
planetstardragon
planetstardragon
Posted 10 Years Ago
Posts: 11.5K,
Visits: 46.0K
i'm trying to load a 4k mov file into iclone, getting an out of memory error ....are we using the vram to load videos ?
BiggsTrek
BiggsTrek
Posted 10 Years Ago
Visits: 12.3K
Peter (RL) (7/19/2016) For those experiencing the Undo > Watermark issue, can you try running "Content - 1 Click Verification" (be warned it might take a long time). In addition can you let us know if the projects affected are stored in your iClone Custom Projects folder or are they saved elsewhere on your computer such as the Desktop?. Thanks.Hi Peter, I clicked the 1 Click verification about 30 mins ago and it's still sitting on 0 %, so I think that's a bust. I'll give it another 30 and see. Also, I store my projects in the default directory (or a sub directory of that, actually.) No place weird...
