Posted 10 Years Ago
Visits: 62.6K
He's still working on it, so check for updates once-in-a-while. ;)
Pollux
Pollux
Posted 10 Years Ago
Visits: 1.8K
Thanks Rampa, this is really cool.
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
Very cool!!!
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
Thank you Rampa. I saw it. But when you select the object after playing in the settings creation, you can't go back to the Spaceship Shelf , isn't it? Anyway it's cool :-)
Posted 10 Years Ago
Visits: 62.6K
There are a few controls. They are located in the bottom section of the tool shelf. Hit "T" on your keyboard to make it visible. If the lower part is not showing, look for a little "+" sign in the lower right corner of the panel, and click or drag it to open the section. You can also find the menu command to open the tool shelf under "view".
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
Thank you Jlittle , it works now. I can just create a random spaceship , I'm trying to understand his sooo few explanation but when I extrude faces it only ...extrude. I don't know how he's creating random procedural detail. But it's the programer world ;-) It's a nice toy anyway. I just generate random pieces that I scale to build a larger one.
Thank you all!!
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K,
Visits: 17.3K
I just upgraded to 2.77a, copied over the "add_mesh_SpaceshipGenerator" folder to the .\2.77\scripts\addons dir, checked it off in the user preferences addons and it works fine. I believe that the folder name needs to be "add_mesh_SpaceshipGenerator" else it won't work right. Jeff
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K,
Visits: 17.3K
Check and make sure the the folder name in ...\scripts\addons is "add_mesh_SpaceshipGenerator". If not then rename it and see if that works. Jeff
planetstardragon
planetstardragon
Posted 10 Years Ago
Posts: 11.5K,
Visits: 46.0K
if he installs the plug in from the zip file, i believe it places the entire folder where it needs to be located, from what i was able to make out of the error, it seems that blender can't find the folders. edit - this posted after I saw your newest post - it seems that blender is saying it can't find the file. - so next guess is if there is some security software, or multiple installations that are blocking it or placing it in wrong location.
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
 It doesn't work with the zip file Planet. But don't be busy for me with this , it's not vital for me ;-) thank you for your help!
