Posted 10 Years Ago
Visits: 62.6K
planetstardragon
planetstardragon
Posted 10 Years Ago
Posts: 11.5K,
Visits: 46.0K
you are finding some great toys, and i now frequent give away of the day every so often because of you! :D thanks for sharing another great find rampa!
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
I follow this tutorial to install the addon but it doesn't works... :-( I've blender 2.77
Alien Maniac
Alien Maniac
Posted 10 Years Ago
Visits: 2.1K
Same problem here.....
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K,
Visits: 17.3K
I got it to work by: Go to your Blender directory (C:\Program Files\Blender Foundation\Blender) and to the directory of your current version used. Mine is 2.76 Go into the scripts\addons directory and copy the folder for the spaceship generator files there. Start Blender and go to File | User Preferences and the Add-Ons tab. Scroll down until you see: "Add Mesh: Spaceship Generator" and place a check in the box to the right. Note: I restarted blender after that but not sure if it is needed. Now in Blender go to the Add | Mesh list and at the bottom you will see Spaceship Generator. Click on it and you've got a spaceship. Jeff
planetstardragon
planetstardragon
Posted 10 Years Ago
Posts: 11.5K,
Visits: 46.0K
don't unzip the file, in blender, install the zip file itself.
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
Thank you jlittle. But your explanation is exactly what the video tutorial said. I did this but when I want to activate the addon I get this error message:  I have the 2.77 blender version and don't want to go backward ;-)
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K,
Visits: 17.3K
I can't read the error message, it's too small. Jeff
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
 It doesn't work with the zip file Planet. But don't be busy for me with this , it's not vital for me ;-) thank you for your help!
planetstardragon
planetstardragon
Posted 10 Years Ago
Posts: 11.5K,
Visits: 46.0K
if he installs the plug in from the zip file, i believe it places the entire folder where it needs to be located, from what i was able to make out of the error, it seems that blender can't find the folders. edit - this posted after I saw your newest post - it seems that blender is saying it can't find the file. - so next guess is if there is some security software, or multiple installations that are blocking it or placing it in wrong location.
