Face animation for unreal engine
Posted By Dan@3DIM 10 Years Ago
Dan@3DIM
Dan@3DIM
Posted 10 Years Ago
Posts: 69, Visits: 791
I was search for solving how to get face animation working after export from 3DXchange. I managed export face bone but fail to export skinning for face bone out of 3DXchange...
In 3DXchange the face animation is working well unless I exporting it out.
What the other way to get face skinning export?
I really want add face animation to my games project.
Dan@3DIM
Dan@3DIM
Posted 10 Years Ago
Nothing? Not even if I buy 3D Max license and import there then use 3D Max FBX exporters to unreal engine? Will that working? What other way can I do it?
valentin.reyjal
valentin.reyjal
Posted 10 Years Ago
Veteran Member (500 reputation)Veteran Member (500 reputation)Veteran Member (500 reputation)Veteran Member (500 reputation)Veteran Member (500 reputation)Veteran Member (500 reputation)Veteran Member (500 reputation)Veteran Member (500 reputation)Veteran Member (500 reputation)
Last Active: 10 Years Ago
Posts: 4, Visits: 45
Hi !
Here is how I did it:
- Open IClone and 3DXchange at the same time.
- Click on your character on IClone then click (on the right panel) on "Edit in 3DXchange". It will open your character in 3DXchange.
- Export the mesh as a FBX without animation using Unreal preset but unselect "Include animation" if it's not already greyed out.
- Import the FBX into Unreal. Materials should be broken. I'm trying to figure out how to fix this...Thanks Reallusion -_-'
- Go back on IClone and animation your character
- Select the animation frames you want to export using the "Collect Clip" raw in the animation timeline
- Right click on the selection and click "Add MotionPlus to 3DXchange" (You definitily need MotionPlus or your facial animations won't be exported)
- It will automatically import the animation into 3DXchange
- In 3DXchange, in the right panel, under "Motion library" select the animation you've just imported and click on "Import".
- The animation is not in the "Perform Edtitor" section.
- Export the animation into a new FBX using Unreal preset but uncheck the "Include Geometry" (you already done it before)
- Import the animation FBX into Unreal using the Skeleton you imported before.
And I think this is it :D
