toonmanbill
toonmanbill
Visits: 786
Just wanted to make a comment. I am so happy that Reallusion has decided to put more effort into supporting many more PSD editors and not having users be dependent on Adobe products. This opens up the doors to more users that can enjoy the software. A lot of people don't use Adobe products anymore. I really like the workflow between CA4, Affinity Designer and/or Clip Studio Paint. Thank you Reallusion !!!
toonmanbill
toonmanbill
Visits: 786
This video may be helpful Affinity Designer is great! https://youtu.be/y7jewO_gAYU
allamosa
allamosa
Last Active: 7 Years Ago
Visits: 426
OK-thanks for the reply.
Ibis Fernandez
Ibis Fernandez
Last Active: 11 Months Ago
Posts: 1.2K,
Visits: 4.3K
allamosa (7/10/2016) Tutor could you please help me with the problem I posted.
Anything I make in Sketchup will not load in 3DExchange and it just shuts the program down when I try to load it.
I thought maybe the file was too big but I made a simple box and got the same results.
The stuff in the 3D warehouse loads with no problem. It seems it is just the stuff I make.Might just be the version number of your sketchup files. try saving your files as a version that is a year or more older so that it is sure to be compatible with your version of 3dxchange. RL doesnt quite put too much emphasis on compatibility updates so most likely you're just using or saving to a version of sketchup that 3dxchange hasn't been updated to support yet.
 Ibis Fernandez | (available for hire) ---------------------------------------------------------------------------------------- Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer Author of Flash Animation and Cartooning: A Creative Guide >>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
allamosa
allamosa
Visits: 426
lesdodds
lesdodds
Visits: 2.6K
vidi (7/8/2016) [quote] Affinity Designer seems to me a stripped Version from DWplus . I'm not very impressed . So many feature are not included. Also NO SWF . But funny to see, how can change a grey GUI the minds. I'm not very impressed Affinity Designer is a lot of hype and very little meat. DrawPlus is far superior to Affinity Designer and Serif is not budging on making improvements such as UI color or SWF export. Corel and Adobe had to learn about dark black UI's being hard on people of age and use in other types of environments. (I use iC 5.5 for this same reason.)
 Lester:) My YouTube My Facebook "All the adversity I've had in my life, all my troubles and obstacles, have strengthened me... You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you." -Walt Disney
allamosa
allamosa
Visits: 426
I was hoping this was an answer to my post about the Sketchup file causing an error message when I try and load it into 3DExchange. Then the entire site closes.
vidi
Posts: 10.8K,
Visits: 40.2K
xara, Illustrator, and Anime Studio have SWF too, but all are useless if only Flash and Draw Plus can do the Layer for CTA X
lesdodds
lesdodds
Visits: 2.6K
jlittle (7/8/2016)
I don't know what formats the new CTA3 will use for importing images and character templates but hopefully it is something other than SWF (which is an older format) since it seems that Adobe will be the only one supporting it.
Jeff
CorelDRAW Home & Student Suite X7 has SWF export.
vidi
Posts: 10.8K,
Visits: 40.2K
Clips Studio/ manga studio shows a bit of promise but nothing on the side of scripting support .
That is pixelbased not vector
2. its the easiest to learn and use 3. Its actually the cheapest optiuon. At $20/mo flash itself is actually the cheapest option out there. CTA 3 should be open to all 2D programs and many formats . .
Flash is not for me the best easiest or cheapest Application . For me personally it is xara . The only reason for Flash to use is the layering for CTA and actually that should be a function in CTA itself That means not matter where I draw and which vector format I use (pdf, ai. eps . svg . swf...) . Import as Sheet and adjust all in CTA 3 .
Afinity Designer seems to me a stripped Version from DWplus . I'm not very impressed . So many feature are not included. Also NO SWF . But funny to see, how can change a grey GUI the minds.
