Diffuse and bump map dont apply on a wall component created in sketchup
Posted By michel.gervais 9 Years Ago
Diffuse and bump map dont apply on a wall component created in...
michel.gervais
michel.gervais
Veteran Member (740 reputation)Veteran Member (740 reputation)Veteran Member (740 reputation)Veteran Member (740 reputation)Veteran Member (740 reputation)Veteran Member (740 reputation)Veteran Member (740 reputation)Veteran Member (740 reputation)Veteran Member (740 reputation)
Last Active: 7 Years Ago
Posts: 12, Visits: 23
Hi Folks,
I have created a wall with holes for windows in sketchup that I couldn't find in the basic building components in iClone. I didn't apply any textures on material on the sketchup model.
When I import it in 3dxchange 6 however, none of the maps (diffuse color, bump map, specular map) that I select in the material pannel are applied on the model. Same thing happens if I export it to iclone 6. non of the texture maps will apply
See the link below
https://forum.reallusion.com/uploads/images/a59fb14f-3c49-4aeb-8d0f-3e7f.png
Is there anything I have to do in sketchup prior to saving the model (saved in sketchup 2015) ?
Thank for helping
Michel
