Diffuse and bump map dont apply on a wall component created in sketchup
Posted By michel.gervais 8 Years Ago
Diffuse and bump map dont apply on a wall component created in...
michel.gervais
michel.gervais
Veteran Member (698 reputation)Veteran Member (698 reputation)Veteran Member (698 reputation)Veteran Member (698 reputation)Veteran Member (698 reputation)Veteran Member (698 reputation)Veteran Member (698 reputation)Veteran Member (698 reputation)Veteran Member (698 reputation)
Last Active: 6 Years Ago
Posts: 12, Visits: 23
Hi Folks,
I have created a wall with holes for windows in sketchup that I couldn't find in the basic building components in iClone. I didn't apply any textures on material on the sketchup model.
When I import it in 3dxchange 6 however, none of the maps (diffuse color, bump map, specular map) that I select in the material pannel are applied on the model. Same thing happens if I export it to iclone 6. non of the texture maps will apply
See the link below
https://forum.reallusion.com/uploads/images/a59fb14f-3c49-4aeb-8d0f-3e7f.png
Is there anything I have to do in sketchup prior to saving the model (saved in sketchup 2015) ?
Thank for helping
Michel
8 Years Ago by michel.gervais
Last Active: 1 minute ago
Posts: 5.7K, Visits: 26.4K
Make sure that you apply a simple Material to the model in SketchUp. Use something that is a jpg file, like one of the default bricks materials. Then you can replace this in either 3DXchange or iClone.
michel.gervais
michel.gervais
Thank you Gerry. I just figured it out right after I posted this.
Space 3D
Space 3D
Distinguished Member (9.0K reputation)Distinguished Member (9.0K reputation)Distinguished Member (9.0K reputation)Distinguished Member (9.0K reputation)Distinguished Member (9.0K reputation)Distinguished Member (9.0K reputation)Distinguished Member (9.0K reputation)Distinguished Member (9.0K reputation)Distinguished Member (9.0K reputation)
Posts: 228, Visits: 1.6K
This reference , import sketchup model to iclone :
- Export model on DAE file included texture data . ( Combine Fbx file )
- Use Autodesk Converter to Fbx format the bring to 3DXchanges -------- > export iclone 5 or 6 .
    - Free Autodesk Converter  - http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=22694909
- Before converted the model on Autodesk Converter  ----------> Use Fbx view from Autodesk  ( Free Software )
    - Free Fbx Autodesk Viewer -  http://www.autodesk.com/products/fbx/fbx-review
Try this methode and see the result :
- Sketchup  ------------>  Obj to iClone
- Sketchup  ------------>  Fbx (Sketchup ) to iClone
- Sketchup  ------------>  DAE then Fbx convereter Autodesk to iClone    ( For me This best way)
- Sketchup  ------------> Skp to iClone
May help.
8 Years Ago by Space 3D
