colour
colour
Posted 15 Years Ago
Posts: 5.2K,
Visits: 8.1K
bluemidget666 (5/5/2011) Hello
Need help I am using River Course A01 from the Medieval Village set but after 8 seconds of animation the water animation stops any Ideas what I am doing wrong.. Thanks
Anyone else having this problemYes - Me. River flow stops at 525 frames:unsure: Only just arrainging / re-arrainging & testing props at the moment - So not fussed. I'll Post a workaround if & when I get it fixed, if I remember. Initial thoghts are; 1) Adding other parts of the River course, either in or out of view, might fix it. 2) Only 2 Keyfranes at Frame 1 for Transform & Material for River. Playing around with Transform Keys, might fix it. 3) If no Fix, using "Empty" River Course B01 & then applyinmg Watewrflow Props might be an alternative.
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS. New Pinhead Website & Project to be announced in September 2015 -----------------------------------------------------------------------------------------
bluemidget666
bluemidget666
Posted 15 Years Ago
Last Active: 10 Years Ago
Posts: 3.5K,
Visits: 13.8K
Hi I have been on to support about this issue and they are looking into fixing this ... though this was a month or so ago.. I have tried using water to replace the default river water but didnt like the results as much...
I Make My Mates Do The CanCan For The Amusement Of Killer Robots:D
Cricky
Cricky
Posted 15 Years Ago
Posts: 2.8K,
Visits: 13.8K
In answer to the issue of the water flow: Look in the Scene Manager for the River Course A01 prop. There is a flow attached to it as a sub-node. The top node River Course has no performs available.If you Right Click on the Sub-Node ( River 01 ) you will get a perform command; Choose the perform command and the water will apply a "IW001" to the River Course on the timeline...then you can stretch it, shrink it, or loop it as needed to speed up, slow down or repeat the water flow as needed. colour (6/16/2011)
Anyone else having this problemYes - Me.River flow stops at 525 frames:unsure: Only just arrainging / re-arrainging& testingprops at the moment - So not fussed. I'll Post a workaround if & when I get it fixed, if I remember. Initial thoghts are; 1) Adding other parts of the River course, either in or out of view, might fix it. 2) Only 2 Keyfranes at Frame 1 for Transform & Material for River.Playing around with Transform Keys,might fix it. 3) If no Fix, using "Empty" River Course B01 & then applyinmg Watewrflow Propsmight be an alternative.
SKYPE ID: rc.650
duchess110
duchess110
Posted 15 Years Ago
Last Active: 6 Years Ago
Posts: 2.0K,
Visits: 15.5K
Looked at what my river did and like your stopped at approx 535. So I did a right click on the river which is attached to the ground/floor selected perform -1w001 or something like that it is called then dragged that to the very start and then did a loop and it then played all the way to the end. Cricky and I posted together but with similar/same suggestion.
Duchess Designs Store
Cricky
Cricky
Posted 15 Years Ago
Posts: 2.8K,
Visits: 13.8K
You owe me a Coke! duchess110 (6/16/2011) Looked at what my river did and like your stopped at approx 535.
SKYPE ID: rc.650
bluemidget666
bluemidget666
Posted 15 Years Ago
Posts: 3.5K,
Visits: 13.8K
Thank you I will have a go at that when i get chance:) Yeahhh works for me ! Thanks#
colour
colour
Posted 15 Years Ago
Posts: 5.2K,
Visits: 8.1K
bluemidget666 (6/16/2011) Thank you I will have a go at that when i get chance:)
Yeahhh works for me ! Thanks#Thanks, both:) But doesn't work for me. In fact the motion won't even start now.:ermm: No worries - I'll figure it out - Eventually. No Coke or cigar - Yet;)
bluemidget666
bluemidget666
Posted 15 Years Ago
Posts: 3.5K,
Visits: 13.8K
Hi colour By any chance did you add the river to tarain then convert it back to a prop as I could not get them working after that...
colour
colour
Posted 15 Years Ago
Posts: 5.2K,
Visits: 8.1K
Just typed a long quoted Reply which got Deleted - Server Error - Typical.
Paumanok West
Paumanok West
Posted 15 Years Ago
Last Active: 12 Years Ago
Posts: 2.5K,
Visits: 7.0K
colour (6/16/2011) Just typed a long quoted Reply which got Deleted - Server Error - Typical.colour, for a long time, I've had the server reject a post when it took longer to compose than the server wants to wait. It sets a timeout after which it refuses to accept a post. If you are working on a post for more a short while, better copy it to your clipboard so you can easily repost. (This is apparently a feature, not a bug...!)
General Picture - animating now to life itself(tm) Member of Content Wizards
