Substance Power 200 OR Substance Live?
Posted By Bawazeer26 10 Years Ago
Bawazeer26
Bawazeer26
Posted 10 Years Ago
Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)
Posts: 9, Visits: 87
Thanks for letting me know :)
will2power71
will2power71
Posted 10 Years Ago
Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)
Posts: 389, Visits: 2.8K
There's one other thing to consider in your purchase since Iclone announced the coming of PBR rendering. With Physically Based Rendering in the pipeline for 2016, then you're going to probably need to do some adjusting on the substance 200 if there's no update or anything covering it. When that happens, you're going to need something that can produce a PBR output, so you may be back to this quandary later on this year. Just keep that in the back of your mind.
Bawazeer26
Bawazeer26
Posted 10 Years Ago
Thanks people!
You're really awesome! All of you
I wish you all the best :)
Posted 10 Years Ago
Posts: 8.2K, Visits: 26.5K
Start with Substance Power 200.
I don't think there is any financial advantage to buying them at the same time.
After you've enjoyed some substances (the legal kind), then you can decide if you'd like to delve into the world of creating and/or modifying your own substances.  Do you want to AUTHOR your own substances?  I got the "Indie Pack" which might not be offered any more, but is probably equivalent to Substance Live.
It's a lot of fun, both Substance Painter and Designer.  As mentioned, for now you need to adjust the output channels to be compatible with iClone, but sometime (per the "What to expect in 2016" thread) we will be able to use the "metallic/roughness" channels in iClone.
bluemidget666
bluemidget666
Posted 10 Years Ago
Last Active: 10 Years Ago
Posts: 3.5K, Visits: 13.8K
Yes the 200 pack is the best starting point for you .
I Make My Mates Do The CanCan For The Amusement Of Killer Robots:D
Bawazeer26
Bawazeer26
Posted 10 Years Ago
So in conclusion, I don't need the Substance Live thing, but if I decided to go deeper into materials and stuff I can do it but with extra efforts to fix the difference you mentioned
I'm I right?
Posted 10 Years Ago
Posts: 8.2K, Visits: 62.6K
If you just need a texture library, then yeah.
If your goal is to learn Substance Designer, then you can probably "fix" all the ones that need it.
Urbanlamb, and a couple other people have converted some of the Substances from the Substance Share site.
bluemidget666
bluemidget666
Posted 10 Years Ago
Ha NOW ..Rampa brought up a good point.
Are you wishing to make and texture your own models or do you just want to plug in some substances into Iclone ?
Bawazeer26
Bawazeer26
Posted 10 Years Ago
So I assume from what you have just said that I should get only Substance Power 200 without the Substance Live thing, I'm I right?
Please correct me if I'm wrong and thanks for the reply
Posted 10 Years Ago
Getting the Software is nice, but the Substances that are available with the Substance Share will not work properly in iClone. The diffuse channel is not mapped to an output for default Substances from Allegorithmic.
The 200 pack ones are all correctly mapped for iClone.
This not a bug, but a difference between rendering engines of different Software.
