Tutorial 1: Creating Morph Slider from OBJ or iAvatar
Posted By Eric (RL) 10 Years Ago
3
GreedyPeopleSuck
GreedyPeopleSuck
Posted 10 Years Ago
Last Active: 7 Years Ago
Posts: 94, Visits: 357
vidi (12/12/2016)
I think your problem is still at the moment, understanding  of all the tools, techniques and workarounds. it End here   in a Turning in the circle
I have no need for Character Creator as ZBrusher. It is useful for mockups and dev art only.
Actually I use zbrush to create all of my moprh for the CC character.
Maybe with more knoweledge in the future  you will understand what we here try to explain .
Good luck to finding your pipeline
I shouldn't have to find any pipeline, it should be clear in the documentation.
I don't know how I missed, but I found this: https://www.youtube.com/watch?v=BFWnWDUk2lM&index=1&list=PLNV5zSFadPdl8bX7wzxg2MGbhRjUvSt5J
The guy with the Asian accent is finally what I was looking for. Now it makes sense why Character Creator exists. Well almost everything makes sense. It's also very clear I was wrong about a few things, but my instinct is very correct. There are major issues with the scope of the software.
The asset store is a waste of time, and it's not a justification for DRM. It may have sounded clever on paper to monetize, but this software is best focused on the animation part, and pipeline to video games. The UI is amazing for doing projects on a small team or individual. If you have a large team, of course there are infinitely more complex ways you can do things. Nowhere in any of this do people have an interest in buying low quality assets.
I'm not happy about having to resculpt for Crazy Talk, I hope this will be addressed, and I sent a support ticket to figure out how I can import a subdivided model back into CC. It errors.
vidi
vidi
Posted 10 Years Ago
Posts: 10.8K, Visits: 40.2K
liebe Grüße vidi
Delerna
Delerna
Posted 10 Years Ago
Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)
Posts: 1.5K, Visits: 14.8K
Actually, i though Crazy talk 8 was a 2D head animation software?
I know you can load a 2D head photo into it and use the photo to make a 3D head which can then be animated.
I knew you can export that 3D head for use in iClone through CC
But can you import a 3D head into CT8?
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
Delerna
Delerna
Posted 10 Years Ago
Iclone, 3dXchange,CTA,CC,CT8
I was mainly saying why you cant change the meshes in CC
I dont use CT8 to animate so i wasnt aware that you had to use CC to import 3D heads into CT8.
Cant say anything about CT8 because i dont use it but sounds like it mightnt have been a good thing to make CC the only way to import into CT8
GreedyPeopleSuck
GreedyPeopleSuck
Posted 10 Years Ago
Delerna (12/11/2016)
Here is how i see it
Character creater is a tool that enables users to easily manipulate the shapes of many of a characters body parts with sliders.
It is quite Similar to Daz.. Using these sliders you can make all kinds of characters for use in iClone
These sliders move specific vertices of the character around to change the shape of that part of the character.
For these sliders to work then the characters mesh structure must always remain the same. You can export the character from CC and change its shape by moving the vertices around. But if you want to be able to bring that character back into CC you cannot add or remove vertices edges or faces. CC wont let you bring the character back into CC if you do that because the morph sliders will no longer work. DAz is exactly the same.
If you want to bring a character that has the mesh modified back into iClone then you need to load it into 3dXchange as a non standard character.
You will be able to animate it in iclone but you will not be able to bring it into CC.
Again, CC is a tool to make character modifications easy for users. But it only works with the base characters that it comes with. All those characters have the same mesh and bone structure and you cannot change that structure if you want the character to work in CC
Yes, I already can do that. I have zero need for Character Creator as a ZBrusher. It's useful for mockups and dev art only. It's shouldn't be needed, but for importing to Crazy Talk 8 it is.  Crazy Talk has very good results for what I want. I want to animate the face of a higher poly model since it exports in 4k. The Character Creator is crippled to 14,000 polys. You cannot import a subdivided model.
I would gladly work in 2D with a workflow to CTA3, but again CTA3 is crippled and you cannot work with raster g3 characters in 360. The wonderful g2.5 has a very awful vector workflow that makes doing it 3D faster if you want to animate multiple angles. Sigh, CTA3 could be good.
It looks like the key for OBJ import is only for DRM to protect models in the nearly pointless asset store. The program is intentionally cucked for this reason.  :-(  All this DRM and it seems like the program suite is pirated by most users. DRM will not stop people from stealing, in this case it looks like the opposite.
This tutorial and this thread has helped reconcile the uniformly poor documentation. Whomever designed the UI for the RA suite is a genius. Whomever is doing the graphic design well...let;s play a game. Which program is which? https://forum.reallusion.com/uploads/images/2f8771dc-7e11-4f12-8fe0-f44b.png
Delerna
Delerna
Posted 10 Years Ago
GreedyPeopleSuck
GreedyPeopleSuck
Posted 10 Years Ago
vidi (12/11/2016)
Why do you have to use Character Creator to use CrazyTalk if you do not need it to use iClone?
In this case, CC is the obj. Importer for the Morph target
The 3D CrazyTalk Head is nothing more than the RL CC Character Mesh.
You can only reshape the base CC mesh, as a morph target,  similar  DAZ Studio Genesis works. A uniform Mesh deform to  many Shapes.
I've only used ZBrush, Blender, and Max  when it comes to 3D. I get blendshapes and morphing, what I don't get is this process. What's the point of the very nimble animation workflow if you can't import art properly?
iClone 6 has a nice UI, but the rendering is early 2000s for now, and I mostly want to quickly do facial animations in Crazy Talk. It can't be possible that nobody thought of using a life like model in Crazy Talk before, no?
You cannot subdivide, it's madness. https://forum.reallusion.com/uploads/images/b13e649d-acb2-48b8-8cc7-139f.png
GreedyPeopleSuck
GreedyPeopleSuck
Posted 10 Years Ago
vidi
vidi
Posted 10 Years Ago
liebe Grüße vidi
GreedyPeopleSuck
GreedyPeopleSuck
Posted 10 Years Ago
Why do you need a morph slider when you could just sculpt a model in ZBrush?
That would break the vertexorder. Like I say before it works only with CC Character Mesh as Morph nothing else
"DO NOT change the total number and structure of the vertex in the OBJ avatar                   by means of any features such as sub-division, slice,                   add/delete vertices... and so on."                [/quote]
That doesn't make much sense though, FBX is an interchange format. Why do you need to use Character Creator to use CrazyTalk, when you don't need it to use iClone? This seems to be a design flaw the software, not anything born out of logic. People who create for production are not going to use the character creator for much besides mockups.
Who wants to resculpt things? It takes a few weeks to model some characters, this is not a fast process, and you need to be able to edit topology.
3
