will2power71
will2power71
Visits: 2.8K
You can see the full sized image on my deviantart page.
will2power71
will2power71
Visits: 2.8K
jarretttowe (1/15/2016) I would like to see how fast you can get it to render at 1080p. The rendered is quite customizable. It won't be realtime but i wonder what quality level you can get at the same speed as a max quality 3x3 iclone final render. To answer your question --about 35 seconds from the time that I hit the render button to the Finished image at 1920 by 1080P. I work with Octane Render in Cinema so render time is about as fast as you can get. I may try Furryball RT one day, but right now I'm pleased with Octane and Cinema.  I didn't really do anything to the scene yet because I've been working on my Genesis 3 Rig, but this will give you an idea of what it looks like. I'll do this scene again when I've got the shaders imported and worked out. In Daz Studio, I use the Redspect TGX Skin Shaders and I'm quite pleased with them. It's only recently that the Octane Plugin for DAZ allows you to export your shaders, so I will do this render again when I've got everything all set up, but I really want to get the animation rig working. Genesis 3 is too new, so I have to do the control rig myself in order to animate it. But I assure you when I have that completed, I will redo this so you can get an idea of the final render time with Hair and lighting.
jarretttowe
jarretttowe
Visits: 3.0K
will2power71
will2power71
Visits: 2.8K
animagic (1/15/2016) I've noted that there are different Cinema 4D versions. What is the minimum that would be required? The Character Object/Auto Rigger is only available in the Cinema 4D Studio Edition. It's available in the student edition as well --which is the full studio version.
Posts: 15.8K,
Visits: 31.4K
will2power71
will2power71
Visits: 2.8K
Yes. You can turn any custom bone setup and control rig into a re-usable character object in order to speed up the animation process. Cinema 4D already has the HumanIK motionbuilder setup, so you could essentially start from there --build the rig one time, then save it as a character object and re-use it. I honestly wouldn't leave iclone if I could get a control rig in the viewport, but since Reallusion doesn't seem to be interested in allowing us to use that animation rig in the viewport, then I had to resort to other avenues to get to where I wanted to go. I've even looked at Akeytsu, which consequently did recognize the DAZ FBX as well but I thought the interface and the documentation on how to use it need a lot more work before I consider going to something like it. I don't know why Reallusion's stuck on the puppet tool. I could even live with it if they allowed you to assign a hotkey to joints so I could select them without having to switch out of the viewport, but I guess that's a pipe dream right now. I like Iclone, but I hate the puppet tools without having the precise control of animating in the viewport instead of trying to string together a bunch of canned motions
Posts: 15.8K,
Visits: 31.4K
Theoretically then, you could do that for an iClone CC character as well, building a Character Object? I'm fine with iClone characters (with the arrival of CC) and rendering, but I'm not happy with the animation results, so I'm interested in learning about alternatives.
jarretttowe
jarretttowe
Visits: 3.0K
Awesome. Makes me want to crack r17 once again.
will2power71
will2power71
Visits: 2.8K
musicaz (1/14/2016) yeah i wish i had cinema 4 d If you want to get your hands on Cinema 4D, the best thing you can do is take a class at community college. If you do that, then you can purchase the student version for $285. I actually have a position at a State University. The education system is at least good for massive educational discounts.
musicaz
musicaz
Visits: 2.5K
