Magique
Magique
Posted 17 Years Ago
Visits: 1.4K
I cleared all animations and started over. That's worked for me so far. Thanks for the help.
Posted 17 Years Ago
Posts: 15.8K,
Visits: 31.4K
In IC3 there are occassional errors in the interpolation between key frames. One problem seems to be that if you change the motion at an existing key frame, things can go wrong. This is not your situation, I know, but it shows that there are some unwanted "features" in the IC3 timeline implementation. As IC4 is coming up, I'm too lazy to notify support, just hope things got fixed, or changed...
stuckon3d
stuckon3d
Posted 17 Years Ago
Posts: 1.8K,
Visits: 7.8K
tscott (9/22/2009) Stuckon3d,
Thanks for the detailed instructions, but I'm fairly certain that iClone is not trying to interpolate between 2 keys that are identical. I think there is some other underlying bug going on here. Hey Scott, just to let you know the interpolation happens across the entire animation curve, so in your case iclone is trying to keep the curve tangency straight at the keyframe points, thus deforming the curve between the two identical keys. If you dont know what im talking about, i can draw you a graph when i get home if you want to. good luck, Stuckon3d
Product Specialist
My iClone 7 gallery
My IMDB
Magique
Magique
Posted 17 Years Ago
Visits: 1.4K
stuckon3d (9/23/2009)[hrHey Scott, just to let you know the interpolation happens across the entire animation curve, so in your case iclone is trying to keep the curve tangency straight at the keyframe points, thus deforming the curve between the two identical keys. If you dont know what im talking about, i can draw you a graph when i get home if you want to.
good luck,
Stuckon3d
That would be incorrect behavior. I don't beleive that is happening. I now have it working correctly with 2 identical keyframes that do indeed hold the position correctly. Something else was going on.
steve_2010022716353194
Posted 10 Years Ago
Last Active: 10 Years Ago
Visits: 15
I am having problems adding a keyframe under 2d animation for body transform. I go to the frame I want to add and double click and no keyframe will be put there. Is there any other way to add the keyframe? I am on a Mac with the latest operating system and I just don't know what to do. Any help is appreciated. Steve
Posted 10 Years Ago
Oops... erroneous post. Ignore.
