Timeline Transform Keyframe Problems
Posted By Magique 17 Years Ago
Posted 10 Years Ago
Posts: 8.2K, Visits: 26.5K
Oops... erroneous post.  Ignore.
steve_2010022716353194
Posted 10 Years Ago
New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)
Last Active: 10 Years Ago
Posts: 2, Visits: 15
I am having problems adding a keyframe under 2d animation for body transform.  I go to the frame I want to add and double click and no keyframe will be put there.  Is there any other way to add the keyframe? I am on a Mac with the latest operating system and I just don't know what to do.  Any help is appreciated.
Steve
Magique
Magique
Posted 17 Years Ago
Posts: 315, Visits: 1.4K
stuckon3d (9/23/2009)[hrHey Scott,
just to let you know the interpolation happens across the entire animation curve, so in your case iclone is trying to keep the curve tangency straight at the keyframe points, thus deforming the curve between the two identical keys. If you dont know what im talking about, i can draw you a graph when i get home if you want to.
good luck,
Stuckon3d
That would be incorrect behavior. I don't beleive that is happening. I now have it working correctly with 2 identical keyframes that do indeed hold the position correctly. Something else was going on.
stuckon3d
stuckon3d
Posted 17 Years Ago
Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)
Posts: 1.8K, Visits: 7.8K
tscott (9/22/2009)
Stuckon3d,
Thanks for the detailed instructions, but I'm fairly certain that iClone is not trying to interpolate between 2 keys that are identical. I think there is some other underlying bug going on here.
Hey Scott,
good luck,
Stuckon3d
Product Specialist
My iClone 7 gallery
My IMDB
Posted 17 Years Ago
Posts: 15.8K, Visits: 31.4K
In IC3 there are occassional errors in the interpolation between key frames. One problem seems to be that if you change the motion at an existing key frame, things can go wrong.  This is not your situation, I know, but it shows that there are some unwanted "features" in the IC3 timeline implementation.
As IC4 is coming up, I'm too lazy to notify support, just hope things got fixed, or changed...
Magique
Magique
Posted 17 Years Ago
I cleared all animations and started over. That's worked for me so far. Thanks for the help.
Cricky
Cricky
Posted 17 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
Yes, as far as the Stacking goes, they can sometimes lay right over each other and you don't see the one underneath. That's why I recommended moving them to the side; I've seen this time and time again.
The simplest method is to Right Click on the Prop while in Frame1 and Select "Remove all Animation", then place it where you want to start from, and go from there.
SKYPE ID: rc.650
Magique
Magique
Posted 17 Years Ago
Stuckon3d,
As far the other post about stacked keys, are you suggesting that there can be 2 keys for the same frame? I'm zoomed in all the way to where I see only a single frame at a time and there is only a single key and no stacking. Did you mean something else by stacking?
As of now, I'm just going to clear all animations for this object and start over. I just hope it doesn't happen again. I'd still very much like to know what's happening here.
stuckon3d
stuckon3d
Posted 17 Years Ago
tscott (9/22/2009)
I am experiencing strange issues with the timeline and I wonder if there is a solution. I have a simple 3D Text object that I want to move from point a to point b, hold for a length of time, and then move on to point c. So what I have are 4 keyframes as follows:
1 - starting position (frame 0)
2 - hold position (frame 30)
3 - hold position (frame 60)
4 - ending position frame (90)
If I have keys 2 & 3 with the exact same position then you would think the object would remain there for 30 frames. However, as I click on the in-between frames, the object drifts backwards out of position. This also happens to me in other areas where there seems to be no interpolation happening between some of the keyframes. I've verifed that no additional keys exist in between #2 and #3, but the result is incorrect.
Exiting and re-loading don't help.
Am I missing something?
Hi Scott,
what you are experiencing is actually common, Iclone is trying to interpolate or inbetween the frames, thats why you get that extra movement inbetween your keys 2 and 3. Here are a couple of trick you might want to try.
1) at keyframe 2 (frame 30) move the timeslider back one frame and create a keyframe there. There is a little icon that allows you to add key on the top row of the timeline.
2) go back to keyframe 2 (frame 30) select key, right click on it and copy key
3) move the time slider forward one frame (frame 31) right click on the empty square and paste key.
4) go to keyframe 3 (frame 60) select key and right click and paste key
5) move back one frame (frame 59) right click on square and paste key again
that should flatten the motion curve for you and stay on hold. If it still wiggles , it mean that the motions between keys 1 and 2 are too extreme to smooth out by brute force which mean you need do a different trick until IC4 comes out. then that problem will be solved with the new motion curve options like step, linear, easy in, etc.
Trick two (if trick one does not work for you.
1) Create a duplicate of the logo with the exact same key frames.
2) Call it logo1 and logo2
3) select logo1 and go to the opacity slider on the modify window. (window along the right side of the screen) scroll down until you see the opacity slider .
4) in the time line go to materials and at frame 30 add key
5) go to frame 31, move the opacity slider to 0 (this will add a new key for you)
6) select logo2 , open the transform tab and delete keyframes 1 and 2
7) open materials tab and go to frame 30 , slide opacity slider to 0
8) go to frame 31 and put opacity slider to 100
9) go to frame 1 and delete key there if there is one.
So this is what is going to happen by doing this, logo1 will be visible only until frame 30, and logo2 is only visible from frame 31 on, and since you removed the transform keyframes 1 and 2 from it, the logo will remain still from frames 31 to 60 and them move to from 61 to 90.
I know this is the long way to do things, but like i said before, this will all be fixed on IC4.
Hope this helped,
Stuckon3d
Product Specialist
My iClone 7 gallery
My IMDB
Cricky
Cricky
Posted 17 Years Ago
Check the TRANSFORM line. Zoom in as close as possible, and look for Stacked Markers (They can be hard to see unless you move one to the side.
SKYPE ID: rc.650
