Timeline Transform Keyframe Problems
Posted By Magique 17 Years Ago
Magique
Magique
Posted 17 Years Ago
Posts: 315, Visits: 1.4K
I am experiencing strange issues with the timeline and I wonder if there is a solution. I have a simple 3D Text object that I want to move from point a to point b, hold for a length of time, and then move on to point c. So what I have are 4 keyframes as follows:
1 - starting position (frame 0)
2 - hold position (frame 30)
3 - hold position (frame 60)
4 - ending position frame (90)
If I have keys 2 & 3 with the exact same position then you would think the object would remain there for 30 frames. However, as I click on the in-between frames, the object drifts backwards out of position. This also happens to me in other areas where there seems to be no interpolation happening between some of the keyframes. I've verifed that no additional keys exist in between #2 and #3, but the result is incorrect.
Exiting and re-loading don't help.
Am I missing something?
Threaded View
Threaded View
Forum Post Timeline Transform Keyframe Problems By Magique ( 17 Years Ago )
Forum Post You might check the MOVE key frame you might have key there that you... By moviechick ( 17 Years Ago )
Forum Post I thought about that and so I opened up every section of the timeline... By Magique ( 17 Years Ago )
Forum Post Start position frame 1 You want it to remain static until frame 30... By duchess110 ( 17 Years Ago )
Forum Post I see you posted between moviechick and my reply with a comment that... By duchess110 ( 17 Years Ago )
Forum Post Well, my keyframes are correct. I can guarantee that. If there is... By Magique ( 17 Years Ago )
Forum Post Check the [u]TRANSFORM[/u] line. Zoom in as close as possible, and... By Cricky ( 17 Years Ago )
Forum Post [quote][b]tscott (9/22/2009)[/b][hr]I am experiencing strange issues... By stuckon3d ( 17 Years Ago )
Forum Post Stuckon3d, Thanks for the detailed instructions, but I'm fairly... By Magique ( 17 Years Ago )
Forum Post Yes, as far as the Stacking goes, they can sometimes lay right over... By Cricky ( 17 Years Ago )
Forum Post Oops... erroneous post. Ignore. By justaviking ( 10 Years Ago )
Forum Post [quote][b]tscott (9/22/2009)[/b][hr]Stuckon3d, Thanks for the... By stuckon3d ( 17 Years Ago )
Forum Post [quote][b]stuckon3d (9/23/2009)[/b][hrHey Scott, just to let you know... By Magique ( 17 Years Ago )
Forum Post I cleared all animations and started over. That's worked for me so... By Magique ( 17 Years Ago )
Forum Post In IC3 there are occassional errors in the interpolation between key... By animagic ( 17 Years Ago )
Forum Post I am having problems adding a keyframe under 2d animation for body... By steve_2010022716353194 ( 10 Years Ago )
