How to get a exact likeness when bringing CT 8 head into CC
Posted By Eric (RL) 10 Years Ago
Eric (RL)
Eric (RL)
Posted 10 Years Ago
Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)
Last Active: 9 Years Ago
Posts: 99, Visits: 1.0K
Hi all!
Before you export the 3D head to Character Creator, please remember to "reset" the character morph in Character Creator! Otherwise the morph data between the head of CrazyTalk 8 will be "blended" with the ones in Character Creator.
You will have to reset the character to the most default state by pressing the "Reset" button every time you started Character Creator, since the character loaded when you started Character Creator contains a few morph changes already.
Here are the step to get the correct 3D Head look in Character Creator.
Open Character Creator, this is the character that greets you when you load up Character Creator. However, she is not in the most default state! Open up the modify panel, select Actor and press the "Reset" button
https://forum.reallusion.com/uploads/images/4c0395ea-20fd-44d1-b80e-2e01.png
After you press the Reset key, it should turn the actor into the most default state, now it is ready for CrazyTalk 8 head.
https://forum.reallusion.com/uploads/images/0f9bafe2-71d6-41aa-add4-ff00.png
Here is an extreme example I have set up to demonstrate what happens when you don't reset the morph.
I have loaded a 3D head of the default character: Sandra. Say I want to bring Sandra's head into Character Creator.
https://forum.reallusion.com/uploads/images/191eeccb-caf5-4884-9c57-ad01.png
Now I have another character loaded in Character Creator, with a bit of "extreme morph"
https://forum.reallusion.com/uploads/images/d5fb1ab4-3c52-4b60-904b-109f.png
If I bring Sandra"s head to Character Creator, the resulting head will be a blend of morph between Character Creator's data and CrazyTalk 8's data, now that doesn't look quite right!
https://forum.reallusion.com/uploads/images/1e6a4f7c-4e0e-4f13-891c-3d13.png
However, if I press the Reset key before I load the 3D head to reset to the default morph:
https://forum.reallusion.com/uploads/images/0da42f0e-7170-4243-b769-33c5.png
Sandra's head should now look exactly as the one in CrazyTalk 8!
https://forum.reallusion.com/uploads/images/30047316-85fc-4a0a-9f8d-afb5.png
Now, because of the lighting and camera focal lens difference between CrazyTalk 8 and Character Creator, there are maybe subtle differences, however the character's head mesh should be exactly the same.
______________________________________
Eric (RL)
Forum Moderator
Reallusion, Inc.
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Threaded View
Threaded View
Forum Post How to get a exact likeness when bringing CT 8 head into CC By Eric (RL) ( 10 Years Ago )
Forum Post Awesome! Thank you. :) By justaviking ( 10 Years Ago )
Forum Post Make sense, now.Now how do we fix the eye's? By brothertcoleman ( 10 Years Ago )
Forum Post I've been looking at this pretty closely over the last day and I'm now... By Kelleytoons ( 10 Years Ago )
Forum Post Try this KT. There is a "max texture resolution" in the CC preferences... By Rampa ( 10 Years Ago )
Forum Post [quote][b]rampa (12/20/2015)[/b][hr]Try this KT. There is a "max... By Kelleytoons ( 10 Years Ago )
Forum Post Hmmm -- the screen you posted, Rampa, gave me another idea. I went... By Kelleytoons ( 10 Years Ago )
Forum Post Hello all,when trying to decide whether to buy CT8 or not and watching... By TonyTiger ( 10 Years Ago )
Forum Post Excellent! Well done RL. The default behaviour makes sense and is far... By pmaina ( 10 Years Ago )
Forum Post I'm a newbie so I may be the only other person experiencing this... By joesorge ( 10 Years Ago )
Forum Post Well, I wouldn't say it is marginal, but I do notice a loss in detail... By Kelleytoons ( 10 Years Ago )
Forum Post It just donned on me as I was walking to the grocery store that the... By Rampa ( 10 Years Ago )
Forum Post [quote][b]rampa (12/21/2015)[/b][hr] This texture map was created with... By animagic ( 10 Years Ago )
Forum Post [quote][b]rampa (12/21/2015)[/b][hr]It just donned on me as I was... By justaviking ( 10 Years Ago )
Forum Post Has anyone found a fix for the resolution issue? I am using a very... By Dorothy Jean ( 6 Years Ago )
Forum Post [quote][b]Dorothy Jean (4/24/2019)[/b][hr]Has anyone found a fix for... By Peter (RL) ( 6 Years Ago )
Forum Post Unfortunately, 2048 x 2048 is the maximum texture size you can... By Dorothy Jean ( 6 Years Ago )
Forum Post [quote][b]Dorothy Jean (4/27/2019)[/b] Hi! I was only getting 1k, how... By Peter (RL) ( 6 Years Ago )
Forum Post Is it possible to use the same front photo that was use for the CT8... By ruscular ( 5 Years Ago )
