Eric (RL)
Eric (RL)
Posted 11 Years Ago
Last Active: 10 Years Ago
Visits: 1.0K
Hi all!
Here you will find currently known issues with CrazyTalk 8, as well as notices when exporting 3D head and script to iClone. Feel free to share any other issues you have encountered in this post!
______________________________________
Eric (RL) Forum Moderator
Reallusion, Inc. https://forum.reallusion.com
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Alien Maniac
Alien Maniac
Posted 11 Years Ago
Visits: 2.1K
Nice one RL..... BUT CT8Pipeline Crashes constantly. Even set up my 3d card and such as run admin. Also isn't full body 3d supposed to show a full 360 view? I am only getting 10 degree front/ side view turns. I will experiment later this weekend and um read the manual. LOL
Thanks for the nice program, I hope to use it soon. If I can get it to stop crashing....LOL
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
Alien Maniac
Alien Maniac
Posted 11 Years Ago
Visits: 2.1K
Here is a problem or two....???. CT8P errors in Win 10 Pro REGISTRY
Wow6432Node----------- The "HKEY_CLASSES_ROOT\Wow6432Node\DefaultIcon" key references the missing "C:\Program Files\Reallusion\CrazyTalk 8\ico" icon. The reference should be deleted so that Windows will not waste time looking for the icon. Missing shared "LiveUpdateSC.exe" fileUnder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\SharedDLLs", the registry references the missing "C:\Program Files (x86)\Common Files\Reallusion\LiveUpdate\LiveUpdateSC.exe" shared file. _______________________________________________________________________ _______________________________________________________________________ Just checking???? Do we need to reinstall all of our packs into CT 8 P? I have these for CT 7 Pro. ______________________________________________________________ CrazyTalk7 Starter Kit – Complete Suite (Windows Version) (Bonus Included)
Organic Auto Motion Samplers Natural Facial Performance Vol. 2 Facial Expression Clips Vol. 2 Auto Animation Library Vol.1 Social Emoticon (Windows) Bouncy Buddies The Grubbies Business Avatars Vol.1 ________________________________________________________________________
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
Bray42 (12/19/2015)
If you want to install your CrazyTalk 7 content in CrazyTalk 8, it is advised to use the Universal Content Downloader rather than manually copying over the content. You can find the download links for the Content Downloader in your Member Account under "Order History".
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
Bray42 (12/18/2015) Nice one RL..... BUT CT8Pipeline Crashes constantly. Even set up my 3d card and such as run admin. Also isn't full body 3d supposed to show a full 360 view? I am only getting 10 degree front/ side view turns. I will experiment later this weekend and um read the manual. LOL
If you are having crashing problems, please contact Technical Support using the link below and please supply your dxdiag.txt. http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspxThanks.
bluemidget666
bluemidget666
Posted 11 Years Ago
Posts: 3.5K,
Visits: 13.8K
Alien Maniac
Alien Maniac
Posted 11 Years Ago
Visits: 2.1K
ERIC
I do not see this update anywhere else even with CT8P update....... "Note: This issue is fixed with a new version: 8.0.1218.2, re-download your CrazyTalk 8 via the order history by logging into your member account!" I re-downloaded CT8P from the Order History, installed it...All OK there. Still crashes badly.
ALSO, all of my packs for CT 7 Pro.......I re-downloaded and installed into CT 8 Pipeline. Nice....all OK but CT8P still crashing after loading and/or startup. Sending DXDIAG.TXT info to support. NOTE: CT7Pro works fine.
Q: What is in the Bonus pack in CT8P (pre release sale?)
NOTE: This pack will not install into CT8 Pipeline (installed back to CT7Pro) I checked the CT8P dir files too. Name: CrazyTalk Voice Script Pack - Social Emoticon
Pack includes: Voice Script x 50 System Requirement =============== CrazyTalk 7.1 or above is required. Notice ===== If you want to backup your files, you might find it in the following path: C:\Documents and Settings\All Users\Documents\Reallusion\Template\CrazyTalk7 Template\Voice Script\Samples\Social Emoticon
bluemidget666
bluemidget666
Posted 11 Years Ago
Posts: 3.5K,
Visits: 13.8K
Forget about the side fitting issues that was me being dumb. The eyes issue is there though often my character disappears after clicking on new eyes.
I Make My Mates Do The CanCan For The Amusement Of Killer Robots:D
Posted 11 Years Ago
Last Active: 7 hours ago
Posts: 15.8K,
Visits: 31.4K
I just checked and still no version 8.0.1218.2.
Posted 11 Years Ago
animagic (12/20/2015) I just checked and still no version 8.0.1218.2.It is there, it's simply mislabeled.Per Eric (RL)... https://forum.reallusion.com/FindPost264429.aspxI double-checked (actually triple-checked) and I do have ".2" installed. The download page says ".1" but the actual product installed in ".2" as verified via "Help --> About." Note: I did my download at 7:00 PM (central time, USA) on December 18... which is 1:00 a.m. December 19 Greenwich Mean Time if I converted correctly.
