duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
With version 1218.1 I have had 2 Qt5 dll crashes. Updated to version 8.0.1218.2 and I have now had my first crash with this version. Again Qt5Core.dll Info of crash Source CrazyTalk 8 AP Summary Stopped working Date 20/12/2015 13:55 Status Report sent Description Faulting Application Path: C:\Program Files\Reallusion\CrazyTalk 8\Bin64\CTApp.exe Problem signature Problem Event Name: APPCRASH Application Name: CTApp.exe Application Version: 8.0.1217.1 Application Timestamp: 56742c45 Fault Module Name: Qt5Core.dll Fault Module Version: 5.4.2.0 Fault Module Timestamp: 5569f229 Exception Code: c0000005 Exception Offset: 0000000000201f82 OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 2057 Additional Information 1: 7540 Additional Information 2: 75400a9e75ceafaf986b049a4dba06fe Additional Information 3: 14cb Additional Information 4: 14cbab32382e0c17db3d59fe82fae3bd Extra information about the problem Bucket ID: 117799761 --------------------------------------------------------------------------------------------- This Qt5Core.dll will also cause me to have crashes in iClone6 also I have reported it in the iClone6.2 issues thread. I am not the only one that has had this error I believe Animagic has also had the same with iClone.
Duchess Designs Store
9 Years Ago by
duchess110
Please remember if you are having issues that are seriously affecting your use of CrazyTalk 8, please contact Technical Support using the link below. Support will then work with you on a one to one basis to help get you up and running. Thanks. http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
Posts: 9.1K,
I put in a support ticket (because it's seriously fracked on my own vanilla system, as I can crash it anytime I want, or even don't want :> but is there a version .2? My own says .1 and when I check it says it's up to date (and on my patch page it says that's the version) but if there's another one floating around I'll be glad to try (I have zero faith it will solve these problems but I can always try).
Kelleytoons (12/23/2015)
I put in a support ticket (because it's seriously fracked on my own vanilla system, as I can crash it anytime I want, or even don't want :> but is there a version .2? My own says .1 and when I check it says it's up to date (and on my patch page it says that's the version) but if there's another one floating around I'll be glad to try (I have zero faith it will solve these problems but I can always try). If you uninstall CrazyTalk 8 and then re-download from your Member Account you will get the latest build. Please try this and see if it helps. Note: You won't need to install all your content again if you uninstall CT8.
pinguintje
pinguintje
Visits: 1.1K
Peter,
Note: You won't need to install all your content again if you uninstall CT8 I uninstalled Pipeline version 8.0.1218.1 and all my content (Template and Custom Map) was gone ( in this case: resource pack and bonus).
Maybe something to look at?
Best Regards and Merry Christmas, Arie
Posts: 9.1K,
Right, that happened to me as well, so I needed to reinstall them. That's different than the way CC and iClone behave, so CT8 most likely needs some fixin' in this regard.
vep
Last Active: 8 Years Ago
Visits: 7
I have this same issue on a mac, I wanted to see if theres an answer, but then on your next post you said "forget about it" did you fixed it? thanks
ace321123
ace321123
Visits: 6
did you ever get a answer, my crazy 8 crashes as soon as i save file, it crashes all the time, i use a brand new imac
didibecker
didibecker
Visits: 126
I always get 2 eyeballs, which basically is cool, BUT the eyeballs are NOT EQUAL in size. What can I do to correct that??
didibecker (4/24/2016) I always get 2 eyeballs, which basically is cool, BUT the eyeballs are NOT EQUAL in size. What can I do to correct that??You can adjust the scale of each eye separately in Eye Settings (Create > Eye Settings). Please see HERE for more details.
