Hello all
I wanted to like this video but using "Blender" instead of "Sculptris".
Before making a long work, I wanted to start with a very simple manipulation.1) I saved the basic avatar belonging to "CC" software.
2) I loaded this avatar in the software "3DXchange 6"
3) I used the "mesh export" and save under the name "test.obj"
4) I imported the "test.obj" file in the "Blender" software. I have not touched anything at all and I exported the avatar as it is in a file called "test-modified.obj".
5) I returned to "3DXchange 6" then I loaded the file "" test-modified.obj "using the" mesh replace ".
The result in pictures :
Before
After :
Where is the problem in your opinion ?
Thank you
9 Years Ago by
Agonos
