Thanks for your reply Peter .
What you said got me to thinking so I checked further with Microsoft and the solution that helped was to Disable display scaling on high DPI settings.
I just right clicked the program-properties-compatibility-checked disable display scaling on high DPI settings.
Microsoft's solution;
Disable display scaling for the app/program
Here’s how:
Step 1: Swipe in from the right edge of the screen, and tap Search.
(If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and click Search.)
Step 2: In the search box, type the name of the app.
Step 3: Select the app’s tile (swipe down on the tile or right-click on it), and tap or click Open file
location to open File Explorer on the desktop.
Step 4: In File Explorer, tap and hold (or right-click) the app’s executable (.exe) file and select Properties.
Step 5: Select the Compatibility tab.
Step 6: In the Settings section, select Disable display scaling on high DPI settings.
Step 7: Tap or click OK.
Step 8: Start the app.
9 Years Ago by
brothertcoleman
