OFFICIAL iClone 6.21 Issues Thread
Posted By Peter (RL) 11 Years Ago
4
5
6
7
8
9
10
Posted 11 Years Ago
Posts: 9.2K, Visits: 22.1K
I'm going to report this as a bug because apparently IC5 didn't work this way and it really should.
A billboard should be able to cast shadows (and respect opacity, natch).  It does not.
Posted 11 Years Ago
Posts: 15.8K, Visits: 31.4K
Kelleytoons (11/14/2015)
Billboards only gave a shadow with the Drop Shadow setting, which is no longer supported in iClone 6. The reason for that is not clear and requests have been made to get it back.
I did a test and I do get Opacity with the Billboard. I'm using a Billboard Facecam instance and when using the Diffuse map as Opacity I can see through it where the text is.
Posted 11 Years Ago
No, opacity works fine for the billboard -- I mean the *shadows* should respect opacity (IOW, not just the billboard itself casting a rectangular shadow).
So drop shadows was a setting outside of billboards?  Or are you saying it was just an option in billboards that was dropped (no pun intended :>)?  If the former then I guess it's something due to a major change in iClone that couldn't support this, but if the latter then it's a very curious omission.  It certainly makes billboards much less useful (almost useless, in fact).
Posted 11 Years Ago
Kelleytoons (11/15/2015)
I agree that shadows should respect opacity. For objects other than billboards they do when Opacity = 0, but there should be a gradation, such as when you have something semi-transparent. This is a problem when using the Sky Tool for example, the shadows of the clouds are just big black blobs and not useable.
That is correct. In iClone 5 there was a choice between Drop shadows, which cast when there is no surface and Self-cast shadows, which cast when there is a surface. iClone 6 has only the latter.
Posted 11 Years Ago
This is not a show stopper, but I often get a crash notice after I close iClone. It always concerns Qt5Core.dll as far as I can tell.
duchess110
duchess110
Posted 11 Years Ago
Last Active: 6 Years Ago
Posts: 2.0K, Visits: 15.5K
animagic (11/15/2015)
+1 I can confirm this I quite often get the same after closing iClone the same Qt5Core.dll
Duchess Designs Store
Lord Ashes
Lord Ashes
Posted 11 Years Ago
Last Active: 8 Months Ago
Posts: 1.3K, Visits: 1.6K
There is a problem with applying new UV settings to CC characters in 3DXChange.
I first noticed this when I used the Replace Mesh function on a CC characters and deselected the "original UV" check box (to apply new UV mappings). The replaced CC mesh imported all distorted. When I used the Replace Mesh without deselecting the "original UV" check box (i.e. not applying new UV mapping) then the CC mesh imports without any issues.
To further study the issue, I imported an unmodified CC character and applied UV changes using the 3DXChange UV settings tab. For testing purposes, I changed the UV Type setting. Immediately after applying the change, the CC mesh gets distorted (similar to the distortion seen using the Replace Mesh function). Since this was done on an unmodified CC mesh, it must be either an issue with the CC meshes or with 3DXchange (i.e. since no mesh modification was done, it cannot be the fault of a 3rd party software).
Next I tested the same with G6 and G5 characters. It seems that the issue does not appear on G6 or G5 characters...it seems to only affect CC characters but it affects both the CC meshes (e.g. clothing) and the RL meshes (e.g. body).
Below is an example of CC mesh distortion that occurs when UV settings are changed on CC characters. In the example, a UV setting change was applied to the CC Base Shirt...
https://forum.reallusion.com/uploads/images/4eeb5dd6-d36a-46f9-ae4b-560b.png
This issue is fairly significant since it is preventing the Replace Mesh function from being fully utilized to make new CC bases which seems to be the only way for users to make custom CC Bases prior to the release of CC PIPELINE. It should be noted that the Replace Mesh function does actually work but in most cases, when using it to create a new CC Base, it will be necessary to also adjust the UV mappings which cannot be done because of this issue.
How To Reproduce Issue:
1. Load CC character into 3DXchange
2. Change some UV settings (e.g. UV Type) for some part of the CC character (such as the clothing). Apply.
Or
2. Use the Replace Mesh | Export Mesh option to export some mesh of the CC character (such as a piece of clothing)
3. Modify the UV mappings on the exported mesh using 3rd party software
4. Use the Replace Mesh | Replace Mesh option to import the exported mesh back into 3DXChange
5. When the Replace Mesh dialog pops up deselect the check box related to original UV mapping (so that 3DXchange tried to load the new UV mapping)
EDIT: Corrected "applying settings" to "applying UV settings". Added last statement about how this issue is limiting the ability to make custom CC Bases. Added steps to reproduce.
Alien Maniac
Alien Maniac
Posted 11 Years Ago
Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)
Posts: 693, Visits: 2.1K
Anyone having a problem with the RL Downloader updates now?
I just updated the CC and RL Downloader via the RL downloader update icon.
Then I went to the MKT place and made a few purchases and tried to download them via RLD.
Com 1.... Will not even load up
Com 2.... RLD ....Disappeared completely and not found on com, hu? Whaaaat??????
I searched on RL site for the RLD to re-download it but searches say NOT FOUND.....hummm
Wo. Anyone else having a problem with this update?
NOW I can not even get what I purchased because only the RLD is offered to install them.
Any ideas or suggestions so I can get my purchased items? I need them today. Doh!
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram,  2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor  External data drives total 7 TB. and an AUDIO Studio Recording system.
Alien Maniac
Alien Maniac
Posted 11 Years Ago
OK, Here is the error message for com 1 When I try to download my products from the MKT place.
FAILED to initialize content install module of iclone 6.0
On com 2.....Nothing happens when I click download, then on install with RLD
humm seems the new RLD update has a bug. ??????
Posted 11 Years Ago
Bray, I just tried this and I could download and install alright. I have had problems in the past with Downloader but not lately.
4
5
6
7
8
9
10
