OFFICIAL iClone 6.21 Issues Thread
Posted By Peter (RL) 11 Years Ago
3
4
5
6
7
10
CaseClosed
CaseClosed
Posted 11 Years Ago
Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)
Posts: 344, Visits: 781
png has an alpha channel. what does the alpha channel look like?
i suspect that is the color of your window, and the alpha channel will show 99% black (1% opacity) for the window.
Posted 11 Years Ago
Posts: 9.2K, Visits: 22.1K
I have to believe this has been reported before, but I'll do it just in case.
Final output to PNG does not respect opacity settings.  It will either make an object completely transparent, or completely opaque, with nothing in between.
Here is glass with opacity (of the material) set at 0:
https://forum.reallusion.com/uploads/images/4a27511b-c8bf-49d2-8d0b-f1ef.png
And then with it set just at 1 (so a TINY notch up):
https://forum.reallusion.com/uploads/images/dff2bc65-8759-4666-a313-7f2c.png
This is also true even if you use a map for opacity but adjust the strength of the map -- can only be either on or off.
The same scene rendered in BMP *does* work properly, so it's a definite bug.
Posted 11 Years Ago
Posts: 15.8K, Visits: 31.4K
Bray, I just tried this and I could download and install alright. I have had problems in the past with Downloader but not lately.
Alien Maniac
Alien Maniac
Posted 11 Years Ago
Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)
Posts: 693, Visits: 2.1K
OK, Here is the error message for com 1 When I try to download my products from the MKT place.
FAILED to initialize content install module of iclone 6.0
On com 2.....Nothing happens when I click download, then on install with RLD
humm seems the new RLD update has a bug. ??????
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram,  2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor  External data drives total 7 TB. and an AUDIO Studio Recording system.
Alien Maniac
Alien Maniac
Posted 11 Years Ago
Anyone having a problem with the RL Downloader updates now?
I just updated the CC and RL Downloader via the RL downloader update icon.
Then I went to the MKT place and made a few purchases and tried to download them via RLD.
Com 1.... Will not even load up
Com 2.... RLD ....Disappeared completely and not found on com, hu? Whaaaat??????
I searched on RL site for the RLD to re-download it but searches say NOT FOUND.....hummm
Wo. Anyone else having a problem with this update?
NOW I can not even get what I purchased because only the RLD is offered to install them.
Any ideas or suggestions so I can get my purchased items? I need them today. Doh!
Lord Ashes
Lord Ashes
Posted 11 Years Ago
Last Active: 8 Months Ago
Posts: 1.3K, Visits: 1.6K
There is a problem with applying new UV settings to CC characters in 3DXChange.
I first noticed this when I used the Replace Mesh function on a CC characters and deselected the "original UV" check box (to apply new UV mappings). The replaced CC mesh imported all distorted. When I used the Replace Mesh without deselecting the "original UV" check box (i.e. not applying new UV mapping) then the CC mesh imports without any issues.
To further study the issue, I imported an unmodified CC character and applied UV changes using the 3DXChange UV settings tab. For testing purposes, I changed the UV Type setting. Immediately after applying the change, the CC mesh gets distorted (similar to the distortion seen using the Replace Mesh function). Since this was done on an unmodified CC mesh, it must be either an issue with the CC meshes or with 3DXchange (i.e. since no mesh modification was done, it cannot be the fault of a 3rd party software).
Next I tested the same with G6 and G5 characters. It seems that the issue does not appear on G6 or G5 characters...it seems to only affect CC characters but it affects both the CC meshes (e.g. clothing) and the RL meshes (e.g. body).
Below is an example of CC mesh distortion that occurs when UV settings are changed on CC characters. In the example, a UV setting change was applied to the CC Base Shirt...
https://forum.reallusion.com/uploads/images/4eeb5dd6-d36a-46f9-ae4b-560b.png
This issue is fairly significant since it is preventing the Replace Mesh function from being fully utilized to make new CC bases which seems to be the only way for users to make custom CC Bases prior to the release of CC PIPELINE. It should be noted that the Replace Mesh function does actually work but in most cases, when using it to create a new CC Base, it will be necessary to also adjust the UV mappings which cannot be done because of this issue.
How To Reproduce Issue:
1. Load CC character into 3DXchange
2. Change some UV settings (e.g. UV Type) for some part of the CC character (such as the clothing). Apply.
Or
2. Use the Replace Mesh | Export Mesh option to export some mesh of the CC character (such as a piece of clothing)
3. Modify the UV mappings on the exported mesh using 3rd party software
4. Use the Replace Mesh | Replace Mesh option to import the exported mesh back into 3DXChange
5. When the Replace Mesh dialog pops up deselect the check box related to original UV mapping (so that 3DXchange tried to load the new UV mapping)
EDIT: Corrected "applying settings" to "applying UV settings". Added last statement about how this issue is limiting the ability to make custom CC Bases. Added steps to reproduce.
duchess110
duchess110
Posted 11 Years Ago
Last Active: 6 Years Ago
Posts: 2.0K, Visits: 15.5K
animagic (11/15/2015)
This is not a show stopper, but I often get a crash notice after I close iClone. It always concerns Qt5Core.dll as far as I can tell.
+1 I can confirm this I quite often get the same after closing iClone the same Qt5Core.dll
Duchess Designs Store
Posted 11 Years Ago
Posted 11 Years Ago
Kelleytoons (11/15/2015)
No, opacity works fine for the billboard -- I mean the *shadows* should respect opacity (IOW, not just the billboard itself casting a rectangular shadow).
I agree that shadows should respect opacity. For objects other than billboards they do when Opacity = 0, but there should be a gradation, such as when you have something semi-transparent. This is a problem when using the Sky Tool for example, the shadows of the clouds are just big black blobs and not useable.
So drop shadows was a setting outside of billboards?
That is correct. In iClone 5 there was a choice between Drop shadows, which cast when there is no surface and Self-cast shadows, which cast when there is a surface. iClone 6 has only the latter.
Posted 11 Years Ago
So drop shadows was a setting outside of billboards?  Or are you saying it was just an option in billboards that was dropped (no pun intended :>)?  If the former then I guess it's something due to a major change in iClone that couldn't support this, but if the latter then it's a very curious omission.  It certainly makes billboards much less useful (almost useless, in fact).
3
4
5
6
7
10
