3dXchange Rotation Orientation issue
Posted By 3doutlaw 11 Years Ago
3doutlaw
3doutlaw
Posted 11 Years Ago
Posts: 59, Visits: 193
So using Aiko3 in Daz, if you look at the picture, you can see the rotation orientation of the fingers. (on the left darker image is Daz, on the right lighter image is 3dX)
When I save as FBX, and then open in 3dXchange, you can see the finger orientation it gets, which makes bending all wonky (its technical term for not working right)
What can I do to make sure the rotation alignment matches the original figure?  Is this an FBX export problem, something I can change in the FBX manually, or a 3dXchange issue?
https://forum.reallusion.com/uploads/images/7a60d9ec-b345-4349-a621-095e.jpg
Threaded View
Threaded View
Forum Post 3dXchange Rotation Orientation issue By 3doutlaw ( 11 Years Ago )
Forum Post I may have found the issue, but I dont know how to fix it....if I... By 3doutlaw ( 11 Years Ago )
Forum Post It's a fairly straight forward change in DAZ, but that may not be... By Cricky ( 11 Years Ago )
Forum Post That seems to work, thanks! ...but it makes me confused??? If I load... By 3doutlaw ( 11 Years Ago )
Forum Post It works because the error is coming from the exported model out... By Cricky ( 11 Years Ago )
Forum Post Thought I'd add this: If you ZERO the figure in Frame ZERO and then... By Cricky ( 11 Years Ago )
Forum Post Yea something went wrong in the versions I have (DS 4.8.0.59, and... By 3doutlaw ( 11 Years Ago )
Forum Post Those weird finger bedings happen with V4 as well. By aspin ( 11 Years Ago )
Forum Post OK, so a couple of questions: 1) Does RL look here for technical... By 3doutlaw ( 11 Years Ago )
Forum Post I am running DAZ 4.8.059 and DAZ 4.6 4.6.0.18 and both export fine... By Cricky ( 11 Years Ago )
Forum Post OK, so here are the steps I took: 1) Open Daz 4.8.0.59 2) Load V4 (I... By 3doutlaw ( 11 Years Ago )
Forum Post You do know Aiko is not Genesis, right? There is a Genesis version of... By Cricky ( 11 Years Ago )
Forum Post Yes, Aiko3 is old school, so is V4. Genesis works fine for me. as... By 3doutlaw ( 11 Years Ago )
Forum Post I'm Throwing in the towel.... By Cricky ( 11 Years Ago )
Forum Post Can someone with 3dXchange 5 and Daz Studio try the steps above, and... By 3doutlaw ( 11 Years Ago )
Forum Post Forget it...I downloaded the iClone5 trial, and it has the same issue.... By 3doutlaw ( 11 Years Ago )
Forum Post I think it may just be you need to "zero-out" all the bones. Once the... By Rampa ( 11 Years Ago )
Forum Post OK... Since the talk is about orientation, I am having a problem... By TalonAnimations ( 11 Years Ago )
