Unfortunately you can not flip the hair sprite.
Since the hair that you are using it is probably a symmetrical implementation the left and right are just mirrored images of each other.
To get what you want you need an asymmetrical hair implementation which does not mirror but uses different drawings for left and right.
You can replace the hair sprites, as needed, with new drawings to get what you want.
Set it up on a copy of the actor, then save the hair object, then you can add the new hair object to your animated character without changing any animation.
Jeff
