I'm playing around with the Indigo render and I must say, it looks pretty good. And although I still have a lot to learn, I already have one crucial question...well, crucial for me that is
:)If you want to render an animation with Indigo, it will do so with sequences. For me it's important to change the background settings, when I use the Indigo Sun and Sky. The default model is 'Captured Simulation'. But this model results in very dark shadows. Not quite realistic. So, I change it to 'Original'. In that case I can change the Turbidity values and create softer shadows.
But...when I render an animation sequence I can't set this 'Original' model and Turbidity value for all sequences. Every time a new sequence is ready for rendering the Backgroud settings go back to the default 'Captured Simulation'.
This is very annoying. And I cannot imagine that this is not an option. I mean, there must be a menu where you can change all the different options/values before rendering an animation, right?
And I know that you can adjust a few values in iClone itself before rendering (Tonemapping). But that's it.
So, now I hope that somebody out there can tell me if it is possible to set the Turbidity value for all the sequences before rendering. And if not, if this is a limitation of the plugin.
