I'm playing around with the Indigo render and I must say, it looks pretty good. And although I still have a lot to learn, I already have one crucial question...well, crucial for me that is
If you want to render an animation with Indigo, it will do so with sequences. For me it's important to change the background settings, when I use the Indigo Sun and Sky. The default model is 'Captured Simulation'. But this model results in very dark shadows. Not quite realistic. So, I change it to 'Original'. In that case I can change the Turbidity values and create softer shadows.
But...when I render an animation sequence I can't set this 'Original' model and Turbidity value for all sequences. Every time a new sequence is ready for rendering the Backgroud settings go back to the default 'Captured Simulation'.
This is very annoying. And I cannot imagine that this is not an option. I mean, there must be a menu where you can change all the different options/values before rendering an animation, right?
And I know that you can adjust a few values in iClone itself before rendering (Tonemapping). But that's it.
So, now I hope that somebody out there can tell me if it is possible to set the Turbidity value for all the sequences before rendering. And if not, if this is a limitation of the plugin.
