iClone 6.03 Update - Now Available
Posted By Peter (RL) 11 Years Ago
Posted 11 Years Ago
Posts: 23.1K, Visits: 36.6K
iClone 6.03 - Now Available
v6.03 (6.03.1622.1) released 29th April-15
Kinect Mocap Plug-in is back for iClone 6! New online content search, Indigo Preset 2.0, transform to path, and many other enhancements.
You can update from your Member Account under "Patch/Bonus" or by clicking "Help > Check For Upgrade" from within iClone 6. Alternatively you can use LiveUpdate.
Please Note: You will need to be using iClone 6.02 to update to version 6.03. If you are using iClone 6.0 or 6.01, please update to iClone 6.02 first.
1) Added & Enhanced
  • Added Device Mocap, supporting Kinect for Windows and Xbox 360 Kinect. Know More
  • Added online content search in Content Manager - both for Content Store and Marketplace. Forum
  • Allow load more 20K polygon object to do the Physice Cloth simulation.
  • Always runs in high performance mode for nVidia and AMD cards, and for notebooks with Independent GPU.
Indigo Plug-in
  • Enhanced color selection, use color picking instead of RGB sliders. Forum
  • Added Foreground Alpha option under Tracing Method for users to save transparent PNG output. Forum
  • Added "Phong - NK Data" preset.
  • Added V.2 Specular preset settings: Transparent, Arch Glass and Single Face settings. Forum
  • Added V.2 Specular Preset: added gain value to adjust color tint level, pass diffuse color to Medium Absorption for crystal clear color tint. Forum
  • Added V.2 Glossy Transparent Preset: added gain value to adjust color strength, pass diffuse color to Medium Absorption.
  • Added embed .igm function for better content portability and easier project sharing.
  • Added Indigo Plug-in online manual.
2) Fixed
Resumed:
  • Resumed Convert Transformation Keys to Path for smoother path-constraint animation control.
Motion & Object Setting Related Defects:
  • Fixed: When using Motion Puppet to record a motion clip, if the clip length reaches to the next clip, motion would not record.
  • Fixed: Character constraint to a path, it moved up while using Direct Puppet.
  • Fixed: When character Transform track contains a keyframe, the character will move if the last frame has a Direct Puppet recording.
  • Fixed: Convert Position to Path does not work.
  • Fixed: Transform gizmos disappear when editing path control points.
  • Fixed: Character Collision Shape saved as .ini Profile doesn't work correctly.
  • Fixed: Pinned soft cloth points will not fall down once pin has been removed.
  • Fixed: Sub-props attached to a larger prop will not be hidden in the Scene manager when converted to Terrain.
Render Related Defects:
  • Fixed: Water does not render the reflection for SpeedTree objects.
  • Fixed: When a 3D scene is applied and water is in the scene, adding a SpeedTree will cause the terrain reflection on the water to disappear.
  • Fixed: Mini Viewport opened would cause tree disappearance in Indigo rendering.
  • Fixed: Certain LOD preference levels will cause billboards to disappear in Indigo renders.
  • Fixed: Cancelling 3D stereo video rendering will show export as successful, but only the audio will export successfully.
  • Fixed: Pixel aspect ratio of video export not correct when exporting 3D stereo video.
Forgotten Settings Defects:
  • Fixed: Final Render setting will disable LOD settings, but the checkbox will still be selected in the Preference menu.
  • Fixed: Input any value for Post Effect Parameter and the value will revert to 0.
  • Fixed: In Particle Key, click another key and the value of the previous key will be forgotten.
  • Fixed: Quality of render settings in the Preference menu will not be remembered upon application re-launch.
Other Defects:
  • Fixed: Right mouse dragging a .jpg to generate an image plane will bring up an error message but still generate the plane.
  • Fixed: When a sub-prop is converted to terrain, disabling the bounding mesh will not affect the sub-prop.
  • Fixed: When dragging a physics constraint object into a billboard, the program will crash.
  • Fixed: Perform menu items for iClone 5 character Jimmy Toon will cause an error message.
  • Fixed: Adjusting the right arm proportion of non-standard character Pocket Pet Foxy will cause program crash.
  • Fixed: Fixed GUI defects in Large Font system (4K Monitor with 200% font size).
  • Fixed: Find Relevant not working correctly.
Threaded View
Threaded View
Forum Post iClone 6.03 Update - Now Available By Peter (RL) ( 11 Years Ago )
Forum Post Yay! Not a lot in the list that directly pertains to what I've been... By justaviking ( 11 Years Ago )
Forum Post Seems as if a lot of time and energy has been invested to turn iClone... By wires ( 11 Years Ago )
Forum Post [quote][b]wires (4/30/2015)[/b][hr]Seems as if a lot of time and... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (4/30/2015)[/b][hr][quote][b]wires... By DELETED2 ( 11 Years Ago )
Forum Post Hi Peter, I am a bit confused about the Indigo preset. You... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (4/30/2015)[/b][hr] I am a bit confused about... By wires ( 11 Years Ago )
Forum Post Would someone please remind me how I uninstall the earlier version of... By Emerald Animation (formerly reelcheapfilms) ( 11 Years Ago )
Forum Post [quote][b]Emerald Animation (formerly reelcheapfilms)... By Peter (RL) ( 11 Years Ago )
Forum Post [quote]Go into "Control Panel > Uninstall A Program" and you will find... By Emerald Animation (formerly reelcheapfilms) ( 11 Years Ago )
Forum Post [quote][b]Emerald Animation (formerly reelcheapfilms)... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (5/1/2015)[/b][hr][quote][b]Emerald Animation... By theschemer ( 11 Years Ago )
Forum Post [quote][b]theschemer (5/2/2015)[/b][hr] I checked the site and it... By wires ( 11 Years Ago )
Forum Post [quote][b]wires (5/3/2015)[/b][hr][quote][b]theschemer... By theschemer ( 11 Years Ago )
Forum Post [quote][b]animagic (5/1/2015)[/b][hr][quote][b] I checked and I have... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (4/30/2015)[/b][hr]Hi Peter, I am a bit... By Peter (RL) ( 11 Years Ago )
Forum Post Thanks Peter. I appreciate the prompt answer. So, from your answer... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (4/30/2015)[/b][hr] On my system now I have... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (4/29/2015)[/b][hr] Added embed .igm function... By hattori kun ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) Youcan update from your Member Account under... By Dragonskunk ( 11 Years Ago )
Forum Post @Dragonskunk, you should be able to manually enter your... By planetstardragon ( 11 Years Ago )
Forum Post [quote][b]planetstardragon (5/2/2015)[/b][hr] @Dragonskunk, you... By Dragonskunk ( 11 Years Ago )
Forum Post Hi Guys I am really having a difficult time working with Iclone in my... By erisku ( 11 Years Ago )
Forum Post imported image show/hide button not active THIS IS AN ICLONE 6... By abla.us ( 11 Years Ago )
Forum Post Imported image show/hide button not active THIS IS AN ICLONE 6... By abla.us ( 11 Years Ago )
Forum Post You can Drag & Drop an image into an iClone scene by using the right... By wires ( 11 Years Ago )
Forum Post [quote][b]wires (5/8/2015)[/b][hr] You can Drag & Drop an image into... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (5/9/2015)[/b][hr][quote][b]wires... By wires ( 11 Years Ago )
Forum Post Why are not addressing the problem of the reflection of the mirror ؟ By tahatv2001 ( 11 Years Ago )
Forum Post [quote][b]tahatv2001 (5/12/2015)[/b][hr]Why are not addressing the... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (5/12/2015)[/b][hr]...//...Maybe because they... By DELETED2 ( 11 Years Ago )
Forum Post [quote][b]Armstrong (5/12/2015)[/b][hr][quote][b]justaviking... By justaviking ( 11 Years Ago )
Forum Post I think this has been mentioned. IC 6.03 Items getting listed... By hattori kun ( 11 Years Ago )
Forum Post I just purchased this program last week. It gave me 6.3 to start.... By rab_63 ( 10 Years Ago )
