Last Active: 7 hours ago
iClone 6.03 - Now Availablev6.03 (6.03.1622.1) released 29th April-15 Kinect Mocap Plug-in is back for iClone 6! New online content search, Indigo Preset 2.0, transform to path, and many other enhancements. You can update from your Member Account under "Patch/Bonus" or by clicking "Help > Check For Upgrade" from within iClone 6. Alternatively you can use LiveUpdate. Please Note: You will need to be using iClone 6.02 to update to version 6.03. If you are using iClone 6.0 or 6.01, please update to iClone 6.02 first. 1) Added & Enhanced iClone - Added Device Mocap, supporting Kinect for Windows and Xbox 360 Kinect. Know More
- Added online content search in Content Manager - both for Content Store and Marketplace. Forum
- Allow load more 20K polygon object to do the Physice Cloth simulation.
- Always runs in high performance mode for nVidia and AMD cards, and for notebooks with Independent GPU.
Indigo Plug-in - Enhanced color selection, use color picking instead of RGB sliders. Forum
- Added Foreground Alpha option under Tracing Method for users to save transparent PNG output. Forum
- Added "Phong - NK Data" preset.
- Added V.2 Specular preset settings: Transparent, Arch Glass and Single Face settings. Forum
- Added V.2 Specular Preset: added gain value to adjust color tint level, pass diffuse color to Medium Absorption for crystal clear color tint. Forum
- Added V.2 Glossy Transparent Preset: added gain value to adjust color strength, pass diffuse color to Medium Absorption.
- Added embed .igm function for better content portability and easier project sharing.
- Added Indigo Plug-in online manual.
2) Fixed Resumed:
- Resumed Convert Transformation Keys to Path for smoother path-constraint animation control.
Motion & Object Setting Related Defects:
- Fixed: When using Motion Puppet to record a motion clip, if the clip length reaches to the next clip, motion would not record.
- Fixed: Character constraint to a path, it moved up while using Direct Puppet.
- Fixed: When character Transform track contains a keyframe, the character will move if the last frame has a Direct Puppet recording.
- Fixed: Convert Position to Path does not work.
- Fixed: Transform gizmos disappear when editing path control points.
- Fixed: Character Collision Shape saved as .ini Profile doesn't work correctly.
- Fixed: Pinned soft cloth points will not fall down once pin has been removed.
- Fixed: Sub-props attached to a larger prop will not be hidden in the Scene manager when converted to Terrain.
Render Related Defects:
- Fixed: Water does not render the reflection for SpeedTree objects.
- Fixed: When a 3D scene is applied and water is in the scene, adding a SpeedTree will cause the terrain reflection on the water to disappear.
- Fixed: Mini Viewport opened would cause tree disappearance in Indigo rendering.
- Fixed: Certain LOD preference levels will cause billboards to disappear in Indigo renders.
- Fixed: Cancelling 3D stereo video rendering will show export as successful, but only the audio will export successfully.
- Fixed: Pixel aspect ratio of video export not correct when exporting 3D stereo video.
Forgotten Settings Defects:
- Fixed: Final Render setting will disable LOD settings, but the checkbox will still be selected in the Preference menu.
- Fixed: Input any value for Post Effect Parameter and the value will revert to 0.
- Fixed: In Particle Key, click another key and the value of the previous key will be forgotten.
- Fixed: Quality of render settings in the Preference menu will not be remembered upon application re-launch.
Other Defects: - Fixed: Right mouse dragging a .jpg to generate an image plane will bring up an error message but still generate the plane.
- Fixed: When a sub-prop is converted to terrain, disabling the bounding mesh will not affect the sub-prop.
- Fixed: When dragging a physics constraint object into a billboard, the program will crash.
- Fixed: Perform menu items for iClone 5 character Jimmy Toon will cause an error message.
- Fixed: Adjusting the right arm proportion of non-standard character Pocket Pet Foxy will cause program crash.
- Fixed: Fixed GUI defects in Large Font system (4K Monitor with 200% font size).
- Fixed: Find Relevant not working correctly.
Yay! Not a lot in the list that directly pertains to what I've been doing, but I still want to take a moment to say "THANK YOU" to the hardworking Reallusion team.
Last Active: 11 minutes ago
Posts: 5.7K,
Visits: 26.4K
Seems as if a lot of time and energy has been invested to turn iClone into a pretty picture making app, as opposed to an animation tool.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Hi Peter, I am a bit confused about the Indigo preset. You mentioned about "Indigo Preset 2.0"... but when I go in my account to "Registration, Patch and Bonus" -> "iClone Render Plug-in for Indigo" -> "Patch/Bonus", I see: Currently release version: v1.03.1622 Size: 31.6 MB (2015/04/29 Update) The date semmes correct but the versoin is old: I would have expected a v.2.0. Is this just a "typo" ? Should we install this plug-in ? What is the right installation order (if any) ? iClone patch first, Indigo plug-in later ? Thanks for the clarifications Cheers Roberto
9 Years Ago by
RobertoColombo
wires (4/30/2015)
Seems as if a lot of time and energy has been invested to turn iClone into a pretty picture making app, as opposed to an animation tool. I see I'm not the only one surprised at the apparent focus of this patch. I, too, thought it was heavily biased toward the Indigo plug-in, which, while nice, seems more like a fringe rather than a core portion of iClone. Any patch is always appreciated, but it does make a person question the priorities.
9 Years Ago by
Posts: 5.7K,
Visits: 26.4K
RobertoColombo (4/30/2015)
Hi Roberto, The Indigo plugin version available for download is the correct one, it looks like RL are trying to keep the last two version digits the same between iClone and the plugin - in this case .03. The plugin will not install if an earlier version is present on your system, you need to first uninstall the older version. Also note that you will need to go through the whole serial nr. entering thing again when you install. I don't think that the installation order has been changed, first the iClone patch and then the plugin.
Emerald Animation...
Visits: 1.1K
Would someone please remind me how I uninstall the earlier version of the Indigo plugin? Thanks!
Emerald Animation (formerly reelcheapfilms) (4/30/2015) Would someone please remind me how I uninstall the earlier version of the Indigo plugin? Thanks!Go into "Control Panel > Uninstall A Program" and you will find it listed. Just choose the Uninstall option from there.
RobertoColombo (4/30/2015) Hi Peter,
Roberto
The iClone 6.03 update should also have updated your Indigo Plugin to the latest build which remains 1.03. If you run into any problems you can always uninstall the Plugin and then install the latest version from your account. If you wish to know a bit more about Indigo Presets 2.0, please see the link below. http://help.reallusion.com/iClone_6_Indigo_Plugin/ENU/Indigo_Plugin/03_Material_Editor/Indigo_V2.htm
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Thanks Peter. I appreciate the prompt answer. So, from your answer it seems that I do NOT have to install the Indigo plug-in available in my account. But what about Gerry's answer ? "The Indigo plugin version available for download is the correct one, it looks like RL are trying to keep the last two version digits the same between iClone and the plugin - in this case .03" At least to me, Gerry' statement sounds different from your one, Peter. On my system now I have the Plug-in 1.03, and the iClone Exporter to Indigo 3.8.17. Note: the Indigo plug-in version shown in iClone completely misses the digits after the 1.03 version, which vice verse are shown in the account (1.03.1622) Really a bit confusing, Peter. Some clarification is welcomed Regards Roberto
9 Years Ago by
RobertoColombo
