planetstardragon
planetstardragon
Posted 10 Years Ago
Last Active: 4 Months Ago
Posts: 11.5K,
Visits: 46.0K
this is what i mean, i took a section of your water where I spotted it, and zoomed in... maybe you may want to check your nvidia control panel settings ?
Space 3D
Space 3D
Posted 10 Years Ago
Visits: 1.6K
This correct. The moving line on sceene
Sometimes there and did not see it
On one render proses Frame 0 -------------> 1800
planetstardragon
planetstardragon
Posted 10 Years Ago
Posts: 11.5K,
Visits: 46.0K
yeah, that definitely sounds more like a video card thing ....it happens with games too... you may want to review one of your settings on your video card to see if something that is incompatible with iclone is enabled....
Space 3D
Space 3D
Posted 10 Years Ago
Visits: 1.6K
by the way , please info us " Best Setting Nvidia Card " for iclone 6
planetstardragon
planetstardragon
Posted 10 Years Ago
Posts: 11.5K,
Visits: 46.0K
your card might be fine, but it may have access to advanced features with textures and anti-aliasing that are not compatible with iclone - iclone is still new to dx11, but dx11 has been doing tons of stuff with anti-aliasing and v-synch for games that might not work with iclone. If that is the case, it's an easy fix, you don't have to change your card for your whole system, you can make a custom profile for iclone.
Space 3D
Space 3D
Posted 10 Years Ago
Visits: 1.6K
Hai friends , water effect alternatife .... for Large Scale
i use another software After effect with red giant tsunami its nice for that , but needed more time for render.
AE red giant tsunami needed 1,30 hour , result good no see line border.
iClone 6 water is good , result good but " see line border on the water "
i think need evaluated for water effect. ( system iclone 6 )
Britlish
Britlish
Posted 10 Years Ago
Visits: 937
I have the same problem. I'm using an AMD R9 270X 4GB card, and have tried to adjust every possible variable to no effect. The size of the water, the angle, the lighting, the video card settings, don't change the fact that there is a noticeable vertical line down the centre of water in the renders.
V2Melody V2Melody is where my three great passions converge: poetry, music, and technology. Here, I explore the musicality inherent in poetry, using modern tools to craft arrangements that breathe new life into beloved verses.
Posted 10 Years Ago
Posts: 15.8K,
Visits: 31.4K
Because it is always a vertical band which only covers the water, it looks like a rendering problem. Water is a different kind of item from other surfaces and for some reason it is not handled correctly. It is also telling that apparently it occurs with NVidia as well as AMD cards. I would suggest entering a bug report in the 6.02 bug thread here: https://forum.reallusion.com/Topic224537-385-1.aspx, including a few of your render samples. You may be requested to provide a project that shows the issue.
Posted 10 Years Ago
Posts: 23.1K,
Visits: 36.6K
Hi Space 3D, Could you please send us the project as I requested in my reply to you via Support. This will help us track down the cause of the problem. Many thanks.
Space 3D
Space 3D
Posted 10 Years Ago
Visits: 1.6K
Hai Peter , Thanks for suport us .
Note : - i have send my project " water effect iclone 6 " on my ticket
