Rendering problems
Posted By KenCoon 11 Years Ago
KenCoon
KenCoon
Posted 11 Years Ago
Last Active: 7 Years Ago
Posts: 687, Visits: 18.4K
How's that for timing. They fixed it while I was asleep!!
Thanks everyone.
Ken:)
Posted 11 Years Ago
Posts: 5.7K, Visits: 26.5K
This problem has now been solved with the new 6.02 patch.
See this thread for details.
urbanlamb
urbanlamb
Posted 11 Years Ago
Posts: 1.2K, Visits: 3.5K
if the project was started in iclone 5 it will work no problem however if you start that project completely in iclone 6 it wont work you can render "all" but you cant render a "range" above 1800 it wont work.
"You have brains in your head. You have feet in your shoes. You can steer yourself in any direction you choose. You're on your own, and you know what you know. And you are the guy who'll decide where to go."
        Dr. Seuss
tahatv2001
tahatv2001
Posted 11 Years Ago
Veteran Member (839 reputation)Veteran Member (839 reputation)Veteran Member (839 reputation)Veteran Member (839 reputation)Veteran Member (839 reputation)Veteran Member (839 reputation)Veteran Member (839 reputation)Veteran Member (839 reputation)Veteran Member (839 reputation)
Last Active: 11 Years Ago
Posts: 47, Visits: 94
Maybe I did not understand the problem well .. I'm not having a problem .. I've implemented a project consists of a 4517 frame a good result without any problems with iclone 6 ..
KenCoon
KenCoon
Posted 11 Years Ago
I had been tempted to do this movie in iClone5.51 already.
The avatars I am using are from 5.51 and I think the scenery is from the same place. If not, it is pretty generic.
the voices will work with either one.
I do have a computer with only iClone 5.51 on it.
Maybe.......
Thanks.
Ken:)
Posted 11 Years Ago
You're not doing anything wrong - this is a bug that has been reported several times already. There is a work-around, but it's not really what you want to hear at the moment.
The "solution", for those that have iClone 5, is to make an empty project in iClone 5 and set the number of frames to a high number and save it. Copy this blank project file into your iClone 6 project folder and open it. Use this project as a base for new projects and you can then render more frames.
I think that this problem was introduced with the 6.01 patch and Reallusion have not mentioned when it will be corrected.
KenCoon
KenCoon
Posted 11 Years Ago
I have set the total frames in the Project settings screen to 4000 and can make a movie up to 4000 if I want.
The current scene goes to 2200. I type in 1 to 2200 in the range when I am in the render screen but as soon as I move from that place it returns to 1800.
I went back and checked and the properties says I can go to 4000 but the render will not let me render that much.
Is there another setting that will permit me to render the complete scene? It is a lady speaking and it takes that long to complete. (No comments on that part.)
I do not know what I am doing wrong.
Ken:)
