Begging for help!
Posted By tknight_20090922190925980 11 Years Ago
Posted 11 Years Ago
Senior Member (475 reputation)Senior Member (475 reputation)Senior Member (475 reputation)Senior Member (475 reputation)Senior Member (475 reputation)Senior Member (475 reputation)Senior Member (475 reputation)Senior Member (475 reputation)Senior Member (475 reputation)
Last Active: 11 Years Ago
Posts: 8, Visits: 34
Well, by the looks of things on the web this is a nasty subject but as many of you are, I too am desperate...
Same old question:
I have a 3d file. I have it in .fbx, .max, .obj all sorts of formats which load perfectly into 3dsMax with textures, materials etc.
When I export it in any format, with the iclone plug-in, as an .obj file etc etc it will never export properly. I get these bland looking objects with no texture, no material etc.
When I load it into 3dxchange it never loads textures or materials...
I would kill for someone to show me how to import ANY 3d object with materials/textures into 3dxchange and then into iclone. I do not think it is possible!
Threaded View
Threaded View
Forum Post Begging for help! By tknight_20090922190925980 ( 11 Years Ago )
Forum Post Hi Tknight, Welcome to the forum. Try using the free autodesk... By planetstardragon ( 11 Years Ago )
Forum Post Hey thanks for the reply! I've tried both the 2012 and 2013 versions... By tknight_20090922190925980 ( 11 Years Ago )
Forum Post ugh, i know what you are talking about - truth is I can't answer why... By planetstardragon ( 11 Years Ago )
Forum Post It has nothing to do with 3DX or ICLONE. I guess it's about the EXPORT... By prabhatM ( 11 Years Ago )
Forum Post Hello! Thanks again. You wrote: I chose to import it in... By tknight_20090922190925980 ( 11 Years Ago )
Forum Post It would help if a file that didn't work on your side be uploaded here... By hattori kun ( 11 Years Ago )
Forum Post Thanks TUTOR!!!! AWESOME STUFF!! Despite the other dudes... By tknight_20090922190925980 ( 11 Years Ago )
Forum Post Swooop! Buddy, SO thankful!! Wow, this place always impresses, so... By tknight_20090922190925980 ( 11 Years Ago )
Forum Post Thanks SO much for this, I am going to try and will report back! ... By tknight_20090922190925980 ( 11 Years Ago )
Forum Post Hey there, I tried your suggestion but no luck! I load in the... By Waaaaaazup ( 11 Years Ago )
Forum Post Hi, I tried all below but no luck. As always, the .max looks great... By Waaaaaazup ( 11 Years Ago )
Forum Post Here is the task in simple terms: Buy a .max model Export it as an... By Waaaaaazup ( 11 Years Ago )
Forum Post UPLOADED SOME PHOTOS TO CLARIFY! - thanks to each of you! Here are... By Waaaaaazup ( 11 Years Ago )
Forum Post my quick noobie fix to this would be to export DAE from Max, then... By planetstardragon ( 11 Years Ago )
Forum Post Hey thanks! I will do this! - export DAE from Max - converting it... By Waaaaaazup ( 11 Years Ago )
Forum Post Tried this, but upon DAE export is always gives me "material export... By Waaaaaazup ( 11 Years Ago )
Forum Post ahh, but not a total fail, this is proving there is a problem with... By planetstardragon ( 11 Years Ago )
Forum Post looks like this is on you tknight imo max is devoid of common sense... By planetstardragon ( 11 Years Ago )
Forum Post This is what the mtl file showed: # 3ds Max Wavefront OBJ Exporter... By Waaaaaazup ( 11 Years Ago )
Forum Post Some people need to learn to use a forum properly or not at all! Just... By momillis ( 11 Years Ago )
