Make the internal fps MATCH the render imaged
Posted By hattori kun 10 Years Ago
hattori kun
hattori kun
Posted 10 Years Ago
Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)
Posts: 868, Visits: 4.1K
Make the internal fps MATCH the image render fps.
For example
With project settings of 2400 fps it should render 2400 images/png, etc(multilayered exrs request)
Currently it renders only half. Always half of 60fps which I assume is the internal fps in Iclone.
I think this is problematic when creating animations and trying to adhere to a lot of variables outside of Iclone.
We can adjust the fps of avi(though I haven't checked if the output is correct,too)
But I don't use avi as a final output, always image sequence for editing in post.
Threaded View
Threaded View
Forum Post Make the internal fps MATCH the render imaged By hattori kun ( 10 Years Ago )
Forum Post [b]+1[/b] For this request, the current system isn't ideal for those... By pumeco ( 10 Years Ago )
Forum Post I'm not against this, but I would like this to be a user option, as I... By animagic ( 10 Years Ago )
Forum Post I think I phrased this backwards. Make the rendered image fps match... By hattori kun ( 10 Years Ago )
Forum Post As has been explained elsewhere, this is not a bug, but by design.... By animagic ( 10 Years Ago )
Forum Post I think you misunderstand the request. The number of images rendered... By hattori kun ( 10 Years Ago )
Forum Post Btw the request to match rendered images to the number of keyframe in... By hattori kun ( 10 Years Ago )
Forum Post I always render to image sequences. If I export at 30 fps, I get 30... By animagic ( 10 Years Ago )
Forum Post The wording and title needs to change :D Really sorry about that its... By hattori kun ( 10 Years Ago )
Forum Post Now try to get a 25FPS animation of the duration "20 sec" or "500... By prabhatM ( 10 Years Ago )
Forum Post This user encountered the issue with his muzzle flash not being... By hattori kun ( 10 Years Ago )
Forum Post True. I use a single frame for the muzzle flash in hitfilm. Imagine... By prabhatM ( 10 Years Ago )
Forum Post [quote][b]prabhatM (2/5/2015)[/b] @hattori While rendering an... By hattori kun ( 10 Years Ago )
Forum Post [quote][b]hattori kun (2/7/2015)[/b][hr][quote][b]prabhatM... By prabhatM ( 10 Years Ago )
Forum Post As an "old-timer" I think there continues to be a misunderstanding... By animagic ( 10 Years Ago )
Forum Post I also was frustrated to discover this fixed frame rate. I... By Dragonskunk ( 10 Years Ago )
Forum Post Another issue is possibly with the indigo exporter. If Iclone is... By hattori kun ( 10 Years Ago )
Forum Post I got Iclone indigo for valentines from the boss, not the boss that... By hattori kun ( 10 Years Ago )
Forum Post I agree 1-1 timeline frame to render frame would be good! today is... By jamie3d ( 10 Years Ago )
