How to import previous iClone version contents into iClone 6?
Posted By Visconti 11 Years Ago
3
4
5
6
7
rampart
rampart
Posted 11 Years Ago
Distinguished Member (15.2K reputation)Distinguished Member (15.2K reputation)Distinguished Member (15.2K reputation)Distinguished Member (15.2K reputation)Distinguished Member (15.2K reputation)Distinguished Member (15.2K reputation)Distinguished Member (15.2K reputation)Distinguished Member (15.2K reputation)Distinguished Member (15.2K reputation)
Last Active: 7 Years Ago
Posts: 1.4K, Visits: 5.1K
This is from the previously mentioned FAQ
There are several methods available to access those previous iClone version contents in iClone 6: -
Method#1 (Traditional Method) - Copy Previous Content to iClone 6 Folders
Manually copy all contents from iClone previous version to iClone 6 in correspondence folder location. Please DO NOT replace the existing folder and files with the same name as this is to avoid any version mismatch.Only copy the specified contents that you wish to use, instead of copy the entire root folder. May we suggest using a file copying utility like: http://www.tgrmn.com/.
From iClone5: -
C:\Users\Public\Documents\Reallusion\Template\iClone 5 Template\iClone Template\
C:\Users\Public\Documents\Reallusion\Custom\iClone 5 Custom
To iClone6: -
C:\Users\Public\Documents\Reallusion\Template\iClone 6 Template\iClone Template
C:\Users\Public\Documents\Reallusion\Custom\iClone 6 Custom
Since these digitally protected contents were not installed using their original installers, or downloaded from BackStage, they need to be re-verified for use in iClone 6.
Please goto main menu, "Help" -> "Content 1-Click Verification", this will help you verify all your templates and custom contents in a single go.
After clicking "Content 1-Click Verification", a confirmation dialog will pop up. Read the information carefully and click on "OK" to begin the verification process.
Again, I repeat this quotation... what does
"Same name as this is to avoid" - What does "this" mean?
How do you convert vns files in iclone 5?
IClone 6 doesn't appear to recognize vns files
I tried Method#4 mentioned in the FAQ for migrating files. It will take days to do this. You have to sit and watch the downloading, and installling because you have prompts between actions. You feel like a slave to a stupid machine as you sit there waiting on the computer to finish a procedure. The installer file is the same name for every file, so you have not choices for speeding up the process. I can invision days of waiting and frustration using this method.
This is dark ages...procedure, maybe if you had one or a couple of files it would be acceptable.
I forgot to mention. The installer will just stop responding at various times. Also, I get error messages when using it. The installer thingy has always been a pain.
Why can't we just have an archived file download and put the files where we want them?
I realize it's mostly about protecting content from piracy, but there has got to be a better way to do this.
Straight talk - IMO, The migration of files from IC5 to IC6 is barely workable.
I am hoping some other users will come up with some sensible workarounds. I don't have much confidence RL will.
RL could have converted all those old vns files to the newer files long ago, or at least had enough respect for buyers of the content not to sell it. As it is, I've bought a bunch of content over the past year that has vns files in it. Now the vns files are my problem, since IC6 can't access them. RL should make revisions of those old content packs and put them on their server. Then have a thread on the forums that tells owners of those content items to update their files. SImple process and I doubt anyone would mind having to update their files.
Anyway, I doubt I will be able to use the IC6 for quite a while. I have too much to do during the week to my spend days doing IC5 to IC6 migrations.
Forgot to mention... when you use the method#4 with the installer the server is downloading at extremely slow speeds. Too bad we can't use the installer with previously downloaded files. I downloaded all the files in my RL orders to keep a respository on my computer.
I have used the IC6 abit, and I think RL has done a terrific job with it.
RobertoColombo
RobertoColombo
Posted 11 Years Ago
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.6K, Visits: 3.0K
Hi Peter,
can you add some guidelines to cover also the following scenario:
IC5 Pro + Contents on PC "A" => IC5 + IC6 Pro + Contents on PC "B"
In simple words: I bought a new PC and I wish to install on it IC5 & IC + all the owned content.
Not sure if the FAQ you mention covers this scenario, because here we also have the "old PC to new PC" variable to be taken into consideration.
I feel I won't be the only one moving to a new PC for IC6, so a detailed procedure would be quite handful.
Thanks in advance for the help
Cheers
Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO + 1x2TB Samsung
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the MOTU M4 I/F) / DirectX: 12
rampart
rampart
Posted 11 Years Ago
Peter (RL) (12/23/2014)
We have updated our FAQ page with some important changes. Please click the link below if you are still having problems getting your content into iClone 6. Thanks.
http://faq.reallusion.com/index.php?action=article&cat_id=011001007002&id=716&lang=
Peter, I appreciate the link to the FAQ page.
It would be excellent if you would - Create one sticky annoncement thread you can bring us up to speed each day on fixes, patches, etc., one thread only. Lock the thread and allow no responses. This way it won't get distorted by thank you, other condolence messages. Pure and simple a daily fixes, and patches thread only. This way we can get direct information from you and RL only, without having to read whines, complaints, or other discussions.
If members want to respond let them start a thread or something.
If I had not previously posted on this thread I wouldn't have read about the updated FAQ.
Thanks,
planetstardragon
planetstardragon
Posted 11 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
@taoistimmortal
there is another technique that you can use that is not widely known.
Go to your iclone 5 folders, right click on the folders you wish to be seen in ic6 - and create a shortcut ....copy that shortcut and place it in the appropriate ic6 folder -
example - go to ic5 avatar folder , make a shortcut.....copy and paste it in the ic6 avatar folder.
after that...the ic5 shortcut will appear as a folder in the content panel in ic6 .
this tip courtesy of Vit3D :)
Cheers and Happy Holidays ☃
"To define Tao is to defile it" - Lao Tzu
Magical Kingdom
Magical Kingdom
Posted 11 Years Ago
Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)
Posts: 7, Visits: 187
Hi all,
All of these methods indicate having 2 identical items in 2 separate content folders (iclone 5 and iClone 6). This will take up double of the space on the hard drive.
Surely, Reallusion could think of something more sensible and economical like :
1. creating virtual folders in iclone 6 pointing to the contents of iClone 5's folders.
2. create a windows shortcut icon in iClone 6 template folder and can be read from iClone 6 Content Library UI.
Please pass on the ideas to the development team.  Thank you and have a merry Christmas :D
Charles
Posted 11 Years Ago
Posts: 23.1K, Visits: 36.6K
dwacon
dwacon
Posted 11 Years Ago
Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)
Last Active: 6 Years Ago
Posts: 352, Visits: 639
I have mixed feelings about content managers. My experiences with Poser and DAZ Studio are not that positive, so I hope that the Old-School/Traditional method will still be available for us oldies...
I have run DAZ installers only to find the content was not there. :crying:
Well, this is 6.0... so I am sure Reallusion will make incremental releases a bit better for us veterans with tons of content.
Right? :unsure:
Atomic Skeletons
[url=http://amzn.to/2zZ3md9]Queer Steer[/url]
Black Larry David
Galactic Blitz
Birthday Movie
Posted 11 Years Ago
Posts: 15.8K, Visits: 31.4K
I simply have too much iClone 5 and earlier content to make the new reinstall method feasible. Downloading everything again would not be very practical... And I have all the install files already.
It would be nice if the Not Installed area would not simply list your on-line inventory, but would actually check what you have already installed and update itself accordingly.
Posted 11 Years Ago
Posts: 5.7K, Visits: 26.5K
I asked a question regarding my inability to download my purchases a few days ago in this post, still waiting for an answer.
dwacon
dwacon
Posted 11 Years Ago
I click on run and I get the box to open or save. I click on open and it tells me it can't connect to the internet.
I have not yet checked to see how much (if any) of my v5 stuff can be seen in v6. I am simply trying to install the Total Plants 2 - Botanical World that I purchased. Disappointed I can’t download it for installation. I get the Download Error Code 301 and have to repeatedly tap Retry to get the installation to creep forward.
I understand this is a new release and hope that they get this resolved quickly!
Atomic Skeletons
Black Larry David
Galactic Blitz
Birthday Movie
3
4
5
6
7
