SchachMatt
SchachMatt
Posted 11 Years Ago
Last Active: 8 Years Ago
Visits: 907
Thanks to you All for your answers!
I use Speccy as well as CPUID HW Monitor (also free) to retrieve the temperature values. The gpu meter gadget I will get and test over the weekend.
Enjoy the weekend, Gerhard
colour
colour
Posted 11 Years Ago
Posts: 5.2K,
Visits: 8.1K
ASUS MOBO PC Probe Configurator & Realtime CPU/MOBO Temps & Fan Speed. Get Speccy Free PC Hardware/Software Analyzer/Monitor. Shows temps of CPU, MOBO, GPU & HDDS.
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS. New Pinhead Website & Project to be announced in September 2015 -----------------------------------------------------------------------------------------
Posted 11 Years Ago
Visits: 62.6K
Sifr (11/22/2014)
SchachMatt (11/21/2014) indeed, I made a change from "let the application decide" to "advanced settings" but switched back now in the NVidea SystemControl; as far as I see now it does not make much of a difference and there are no further settings made by me;
which "process monitor" do have in mind?Try the widget on the sidebar on Win 7. It's called gpu monitor, I miss this in Win 8. http://addgadgets.com/gpu_meter/ That's the one I used as well. Also miss it. I'm running 8.1 now.
colour
colour
Posted 11 Years Ago
Posts: 5.2K,
Visits: 8.1K
SchachMatt (11/21/2014) - the fans are clean as well as the PC´s interior
- my latest experience: the energy options of W7 have an impact on CPU temp: - energy saving mode: ~ 40°C - balanced mode: ~ 50°C - high power mode: 70° up to sporatically 100°
I checked Intel: the 4790 has a max. operating temp of 72,72°C and an updated temp. management which reduces CPU´s load when temp goes up to 100°C which is prevented by the fans. 150°C seems to be a real critical value!
I have not experienced any forced shut-down sofar; but for sure, higher temps reduce the CPU´s life-span. For the moment I use Windows 7 energy saving mode.
1) W7 Power Options, here, are Default; Balanced Mode. 2) Max CPU temperatures & Fan speeds here, are controlled by ASUS MOBO. CPU Temperature & Fan speeds can be customised via ASUS MOBO Probe Program. Anything above the Default Maximum will display a red warning. My Settings are set at Default. 3) No AMD/ATI GPU Control Panel Priority Settings here re; Rampa's Post, that I'm aware of. But there are in Windows OS Settings. The Default is; "Let Windows Decide". 4) I repeat my first Post that, IMO, iClone Program "decides" when it's using CPU/GPU. 5) Ensuring that all Settings above are set at Default, "Might" fix the problem.
Sifr
Last Active: 6 Months Ago
Visits: 3.7K
---------------------------------------------------------------------------------------------- Reallusion iClone & CC Pipeline --- Plugins: Iray HeadShot SkinGen. CrazyTalk Animator Pipeline, CrazyTalk, Maya LT, Daz, Substance Painter Indie, Substance Designer Indie, B2M Pro+ Substance Live, Sculptris, Wrap, Unity, UE4, Perception Neuron Ready:):D:P;):cool::hehe::smooooth::crazy::satisfied::Wow::pinch::exclamation::alien::discuss::kiss::arrow::(:angry::sick::exclamation::blush::Whistling::w00t::w00t::w00t: SurfaceBook 2 Windows 11 Pro 64-bit Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz -2.11 GHz 512GB Solid State Hard Drive 8GB RAM Nvidia GeForce 1050GTX Dell Alienware m18X R2 18.5" Custom Convertible Tablet Windows 8.1 Pro 64-bit Intel Core I7-3840QM 2.80GHz Quad Core 8 Thread 3.2GHz Turbo 512GB Solid State Hard Drive+1TB X2 RAID Disk Drive 32GB RAM Nvidia Geforce GTX 680m 2GB X2 SLI Custom Multi-touch. Dagi capacitive touch stylus Microsoft Surface Pro 2 10.1" Tablet Windows 10 64-bit Intel Core I5-4200U 1.60GHz 2.3GHz Turbo 128GB Solid State Hard Drive 4GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer screen Surface Pen+Axiotron Studio Pen Asus Vivo Tab 8" Tablet Windows 10 32-bit Intel Atom Z-3740 1.33GHz Quad Core 32GB Solid State Hard Drive 2GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer Wacom stylus.
SchachMatt
SchachMatt
Posted 11 Years Ago
Visits: 907
Posted 11 Years Ago
Visits: 62.6K
You might want to watch a process monitor and see if iClone is using your GPU. It should be using it quite a lot!
Check in the control panel of your GPU to see if it's set to something custom that is preventing iClone from utilizing it. I keep my settings on "let the program decide", but I know that you can set custom settings for individual programs.
SchachMatt
SchachMatt
Posted 11 Years Ago
Visits: 907
SchachMatt
SchachMatt
Posted 11 Years Ago
Visits: 907
the fans are clean as well as the PS´interior the energy options of W7 have an impact: energy saving mode
colour
colour
Posted 11 Years Ago
Posts: 5.2K,
Visits: 8.1K
SchachMatt (11/21/2014) Thanks, Colour, for your response, Well, I think I need to get deeper into the cooling topic. Greetings from Germany, Gerhard40 -50 is within acceptable limits. 70 & certainly not 90, aren't. Your CPU/MOBO should have a safety cut-out that shuts-down you PC, when those temperatures are reached. Excessive dust can also cause overheating.
