SchachMatt
SchachMatt
Posted 12 Years Ago
Last Active: 9 Years Ago
Visits: 907
Hello Forum,
my PC: i7-4790, 4*3,6GHz, 16GB RAM, GTX-770 with 2GB, W7.
When using iClone5 my CPU indicates higher temperatures (40°C - 50°C , sometimes 70°C) while the GPU "sleepes" at 25°C to 30°C. At critical moments, CPU temperature goes to 90°C, which is not good at all. GPU would accept 80°C quite easily.
My impression: the CPU is doing all the work, while the GPU is sleeping.
What could I do to "transfer" load from the CPU to the GPU?
Greetings from Germany,
Gerhard
colour
colour
Posted 12 Years Ago
Posts: 5.2K,
Visits: 8.1K
IMO, it's iC5 Program itself that dictates whether or not it's using CPU over GPU & Vica versa, at any given time. Therefore, IMO, you can't direct iClone to use less CPU & more GPU. In an NLE Program environment, the GPU Renders Video Effects. All other eg; sound is CPU Rendered. It sounds like your PC has a physical overheating problem. Check your CPU Heatsink & MOBO/PC Case Fans are functioning correctly. You need to check CPU & GPU temperatures before & after Running iClone. My ASUS MOBO monitors MOBO & CPU temperatures, automatically adjusting CPU Heatsink & PC Case Fans speed, to maintain optimum temperatures. Never more than 50 degrees at any given time. Usually between 35-45 degrees, when Running iC5. ADDED - And overclocking the CPU without sufficient cooling, can dramatically increase it's temperature & fry your MOBO, if you're not careful. Anyone-else?
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS. New Pinhead Website & Project to be announced in September 2015 -----------------------------------------------------------------------------------------
SchachMatt
SchachMatt
Posted 12 Years Ago
Visits: 907
Thanks, Colour, for your response, Well, I think I need to get deeper into the cooling topic. Greetings from Germany, Gerhard
colour
colour
Posted 12 Years Ago
Posts: 5.2K,
Visits: 8.1K
SchachMatt (11/21/2014) Thanks, Colour, for your response, Well, I think I need to get deeper into the cooling topic. Greetings from Germany, Gerhard40 -50 is within acceptable limits. 70 & certainly not 90, aren't. Your CPU/MOBO should have a safety cut-out that shuts-down you PC, when those temperatures are reached. Excessive dust can also cause overheating.
SchachMatt
SchachMatt
Posted 12 Years Ago
Visits: 907
the fans are clean as well as the PS´interior the energy options of W7 have an impact: energy saving mode
SchachMatt
SchachMatt
Posted 12 Years Ago
Visits: 907
- the fans are clean as well as the PC´s interior
- my latest experience: the energy options of W7 have an impact on CPU temp: - energy saving mode: ~ 40°C - balanced mode: ~ 50°C - high power mode: 70° up to sporatically 100°
I checked Intel: the 4790 has a max. operating temp of 72,72°C and an updated temp. management which reduces CPU´s load when temp goes up to 100°C which is prevented by the fans. 150°C seems to be a real critical value!
I have not experienced any forced shut-down sofar; but for sure, higher temps reduce the CPU´s life-span. For the moment I use Windows 7 energy saving mode.
Posted 12 Years Ago
Visits: 62.6K
You might want to watch a process monitor and see if iClone is using your GPU. It should be using it quite a lot!
Check in the control panel of your GPU to see if it's set to something custom that is preventing iClone from utilizing it. I keep my settings on "let the program decide", but I know that you can set custom settings for individual programs.
SchachMatt
SchachMatt
Posted 12 Years Ago
Visits: 907
indeed, I made a change from "let the application decide" to "advanced settings" but switched back now in the NVidea SystemControl; as far as I see now it does not make much of a difference and there are no further settings made by me;
which "process monitor" do have in mind?
Sifr
Visits: 3.7K
SchachMatt (11/21/2014) indeed, I made a change from "let the application decide" to "advanced settings" but switched back now in the NVidea SystemControl; as far as I see now it does not make much of a difference and there are no further settings made by me;
which "process monitor" do have in mind?Try the widget on the sidebar on Win 7. It's called gpu monitor, I miss this in Win 8. http://addgadgets.com/gpu_meter/
---------------------------------------------------------------------------------------------- Reallusion iClone & CC Pipeline --- Plugins: Iray HeadShot SkinGen. CrazyTalk Animator Pipeline, CrazyTalk, Maya LT, Daz, Substance Painter Indie, Substance Designer Indie, B2M Pro+ Substance Live, Sculptris, Wrap, Unity, UE4, Perception Neuron Ready:):D:P;):cool::hehe::smooooth::crazy::satisfied::Wow::pinch::exclamation::alien::discuss::kiss::arrow::(:angry::sick::exclamation::blush::Whistling::w00t::w00t::w00t: SurfaceBook 2 Windows 11 Pro 64-bit Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz -2.11 GHz 512GB Solid State Hard Drive 8GB RAM Nvidia GeForce 1050GTX Dell Alienware m18X R2 18.5" Custom Convertible Tablet Windows 8.1 Pro 64-bit Intel Core I7-3840QM 2.80GHz Quad Core 8 Thread 3.2GHz Turbo 512GB Solid State Hard Drive+1TB X2 RAID Disk Drive 32GB RAM Nvidia Geforce GTX 680m 2GB X2 SLI Custom Multi-touch. Dagi capacitive touch stylus Microsoft Surface Pro 2 10.1" Tablet Windows 10 64-bit Intel Core I5-4200U 1.60GHz 2.3GHz Turbo 128GB Solid State Hard Drive 4GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer screen Surface Pen+Axiotron Studio Pen Asus Vivo Tab 8" Tablet Windows 10 32-bit Intel Atom Z-3740 1.33GHz Quad Core 32GB Solid State Hard Drive 2GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer Wacom stylus.
colour
colour
Posted 12 Years Ago
Posts: 5.2K,
Visits: 8.1K
SchachMatt (11/21/2014) - the fans are clean as well as the PC´s interior
1) W7 Power Options, here, are Default; Balanced Mode. 2) Max CPU temperatures & Fan speeds here, are controlled by ASUS MOBO. CPU Temperature & Fan speeds can be customised via ASUS MOBO Probe Program. Anything above the Default Maximum will display a red warning. My Settings are set at Default. 3) No AMD/ATI GPU Control Panel Priority Settings here re; Rampa's Post, that I'm aware of. But there are in Windows OS Settings. The Default is; "Let Windows Decide". 4) I repeat my first Post that, IMO, iClone Program "decides" when it's using CPU/GPU. 5) Ensuring that all Settings above are set at Default, "Might" fix the problem.
