Increase GPU usage
Posted By SchachMatt 11 Years Ago
SchachMatt
SchachMatt
Posted 11 Years Ago
Last Active: 8 Years Ago
Posts: 239, Visits: 907
Hello Forum,
my PC: i7-4790, 4*3,6GHz, 16GB RAM, GTX-770 with 2GB, W7.
When using iClone5 my CPU indicates higher temperatures (40°C - 50°C , sometimes 70°C) while the GPU "sleepes" at 25°C to 30°C. At critical moments, CPU temperature goes to 90°C, which is not good at all. GPU would accept 80°C quite easily.
My impression: the CPU is doing all the work, while the GPU is sleeping.
What could I do to "transfer" load from the CPU to the GPU?
Greetings from Germany,
Gerhard
colour
colour
Posted 11 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
IMO, it's iC5 Program itself that dictates whether or not it's using CPU over GPU & Vica versa, at any given time. Therefore, IMO, you can't direct iClone to use less CPU & more GPU.
In an NLE Program environment, the GPU Renders Video Effects. All other eg; sound is CPU Rendered.
It sounds like your PC has a physical overheating problem. Check your CPU Heatsink & MOBO/PC Case Fans are functioning correctly.
You need to check CPU & GPU temperatures before & after Running iClone.
My ASUS MOBO monitors MOBO & CPU temperatures, automatically adjusting CPU Heatsink & PC Case Fans speed, to maintain optimum temperatures. Never more than 50 degrees at any given time. Usually between 35-45 degrees, when Running iC5.
ADDED - And overclocking the CPU without sufficient cooling, can dramatically increase it's temperature & fry your MOBO, if you're not careful.
Anyone-else?
SchachMatt
SchachMatt
Posted 11 Years Ago
Thanks, Colour,
for your response,
Well, I think I need to get deeper into the cooling topic.
Gerhard
colour
colour
Posted 11 Years Ago
SchachMatt (11/21/2014)
Thanks, Colour,
for your response,
Gerhard
40 -50 is within acceptable limits. 70 & certainly not 90, aren't. Your CPU/MOBO should have a safety cut-out that shuts-down you PC, when those temperatures are reached.
Excessive dust can also cause overheating.
SchachMatt
SchachMatt
Posted 11 Years Ago
the fans are clean as well as the PS´interior
the energy options of W7 have an impact:
energy saving mode
SchachMatt
SchachMatt
Posted 11 Years Ago
- the fans are clean as well as the PC´s interior
- my latest experience: the energy options of W7 have an impact on CPU temp:
- energy saving mode: ~ 40°C
- balanced mode: ~ 50°C
- high power mode: 70° up to sporatically 100°
I checked Intel: the 4790 has a max. operating temp of 72,72°C and an updated temp. management which reduces CPU´s load when temp goes up to 100°C which is prevented by the fans. 150°C seems to be a real critical value!
I have not experienced any forced shut-down sofar; but for sure, higher temps reduce the CPU´s life-span. For the moment I use Windows 7 energy saving mode.
Posted 11 Years Ago
Posts: 8.2K, Visits: 62.6K
You might want to watch a process monitor and see if iClone is using your GPU. It should be using it quite a lot!
Check in the control panel of your GPU to see if it's set to something custom that is preventing iClone from utilizing it. I keep my settings on "let the program decide", but I know that you can set custom settings for individual programs.
SchachMatt
SchachMatt
Posted 11 Years Ago
indeed, I made a change from "let the application decide" to "advanced settings" but switched back now in the NVidea SystemControl; as far as I see now it does not make much of a difference and there are no further settings made by me;
which "process monitor" do have in mind?
Sifr
Sifr
Posted 11 Years Ago
Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)
Last Active: 6 Months Ago
Posts: 647, Visits: 3.7K
Try the widget on the sidebar on Win 7. It's called gpu monitor, I miss this in Win 8.
http://addgadgets.com/gpu_meter/
Reallusion iClone & CC Pipeline --- Plugins: Iray HeadShot SkinGen.  CrazyTalk Animator Pipeline, CrazyTalk, Maya LT, Daz, Substance Painter Indie, Substance Designer Indie, B2M Pro+ Substance Live, Sculptris, Wrap, Unity, UE4, Perception Neuron Ready:):D:P;):cool::hehe::smooooth::crazy::satisfied::Wow::pinch::exclamation::alien::discuss::kiss::arrow::(:angry::sick::exclamation::blush::Whistling::w00t::w00t::w00t:
SurfaceBook 2 Windows 11 Pro 64-bit Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz -2.11 GHz 512GB Solid State Hard Drive 8GB RAM Nvidia GeForce 1050GTX
Dell  Alienware m18X R2 18.5" Custom Convertible Tablet Windows 8.1 Pro 64-bit Intel Core I7-3840QM 2.80GHz Quad Core 8 Thread 3.2GHz Turbo 512GB Solid State Hard Drive+1TB X2 RAID Disk Drive 32GB RAM Nvidia Geforce GTX 680m 2GB X2 SLI Custom Multi-touch. Dagi capacitive touch stylus
Microsoft Surface Pro 2 10.1" Tablet Windows 10 64-bit Intel Core I5-4200U 1.60GHz 2.3GHz Turbo 128GB Solid State Hard Drive 4GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer screen Surface Pen+Axiotron Studio Pen
Asus Vivo Tab 8" Tablet Windows 10 32-bit Intel Atom Z-3740 1.33GHz Quad Core 32GB Solid State Hard Drive 2GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer Wacom stylus.
colour
colour
Posted 11 Years Ago
1) W7 Power Options, here, are Default; Balanced Mode.
2) Max CPU temperatures & Fan speeds here,  are controlled by ASUS MOBO. CPU Temperature & Fan speeds can be customised via ASUS MOBO Probe Program. Anything above the Default Maximum will display a red warning. My Settings are set at Default.
3) No AMD/ATI GPU Control Panel Priority Settings here re; Rampa's Post, that I'm aware of. But there are in Windows OS Settings. The Default is; "Let Windows Decide".
4) I repeat my first Post that, IMO, iClone Program "decides" when it's using CPU/GPU.
5) Ensuring that all Settings above are set at Default, "Might" fix the problem.
