outofbath (5/25/2014)
Hi,
Just to say the new Mac version of CTA2 is great and seems to be running well.
I have however encountered one glitch with jumping text boxes. I have attached a couple of images as examples. The timeline also jumps up the screen if I add or take away tracks that I'm working with. One working around is to always keep the timeline docked, though is obviously not ideal. Some of the text box options can only be seen by moving the whole work panel down before clicking the button as otherwise they are off the screen.
I have attached my computer specs too.
Keep up the great work.
Many thanks,
LukeHi Luke,
Thanks for notifying us of this problem.
Are you using the latest build which is 2.11.1712? If you are unsure you can check by going to Help > Check For Update. If you do not have this latest build please update and check again to see if the problem continues.
If it does continue, please can you contact Technical Support using the link below. They will be able to investigate this issue for you. Thanks.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
