SketchUp with iClone4 pro
Posted By Heatseeker 10 Years Ago
Heatseeker
Heatseeker
Posted 10 Years Ago
Veteran Member (641 reputation)Veteran Member (641 reputation)Veteran Member (641 reputation)Veteran Member (641 reputation)Veteran Member (641 reputation)Veteran Member (641 reputation)Veteran Member (641 reputation)Veteran Member (641 reputation)Veteran Member (641 reputation)
Last Active: 10 Years Ago
Posts: 16, Visits: 21
Hi, I'm wondering if it's worthwhile downloading SketchUp Make to use with iClone4. It's something else to learn and I've read that the download could be 'Iffy'. Unsure
Any ideas would be great, thanks in advance.Smile
planetstardragon
planetstardragon
Posted 10 Years Ago
Posts: 11.5K, Visits: 45.9K
Hi Heatseeker,
Welcome to the forum Smile
It would be worth if only if you had 3Dxchange - which is the software used to import/convert 3rd party models for iclone. Otherwise iclone alone won't be able to import anything beyond it's own proprietary formats.
Sketchup isn't so hard to learn to make simple stuff - it's not to say that you can't build more complex structures with it also - ie built to scale / spec with extreme detail - but for basic nice iclone models for filming it's fairly simple / straightforward.
Cheers!
Heatseeker
Heatseeker
Posted 10 Years Ago
planetstardragon (2/1/2014)
Hi Heatseeker,
Cheers!
Hi planetstardragon,thanks for your help. I do have 3DXchange so I will probably have a go with SketchUp.
Thanks again for your help and advice. Smile
Posted 10 Years Ago
Last Active: 5 hours ago
Posts: 5.7K, Visits: 26.4K
One thing to think about if you plan to use the latest version of SketchUp. 3DXchange only supports SketchUp .skp files up to version 8.
In order to use models created with the new version you need to use the "Save As" option under "File" and select Sketchup version 8 from the drop down list.
Heatseeker
Heatseeker
Posted 10 Years Ago
wires (2/2/2014)
Thanks for that Wires, I'm using 3DXchange 4 pro, am I right to assume SketchUp V8 will be okay with that.Smile
Posted 10 Years Ago
SketchUp ver. 7 & 8 models can be opened in 3DXchange 4.11, any version before that could only open models from SketchUp ver. 6.
Heatseeker
Heatseeker
Posted 10 Years Ago
That's great, 3DXchange 4.11 is exactly what I have, thanks GerrySmile
BiggsTrek
BiggsTrek
Posted 10 Years Ago
Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)
Posts: 914, Visits: 11.9K
I also recommend Sketchup 8 rather than the very latest.
Smile
https://marketplace.reallusion.com/iclone/author/biggstrek
Posted 10 Years Ago
Last Active: 11 hours ago
Posts: 15.7K, Visits: 30.5K
biggstrek (2/2/2014)
Smile
I agree. Sketchup Make (the latest) has a very restrictive EULA.
