Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
biggstrek (2/2/2014) I also recommend Sketchup 8 rather than the very latest.
:)I agree. Sketchup Make (the latest) has a very restrictive EULA.
BiggsTrek
BiggsTrek
Posted 11 Years Ago
Last Active: 5 Months Ago
Visits: 12.3K
I also recommend Sketchup 8 rather than the very latest. :)
 https://marketplace.reallusion.com/iclone/author/biggstrek
Heatseeker
Heatseeker
Posted 11 Years Ago
Last Active: 11 Years Ago
Visits: 21
That's great, 3DXchange 4.11 is exactly what I have, thanks Gerry:)
Posted 11 Years Ago
Last Active: 4 Months Ago
Posts: 5.7K,
SketchUp ver. 7 & 8 models can be opened in 3DXchange 4.11, any version before that could only open models from SketchUp ver. 6.
Heatseeker
Heatseeker
Posted 11 Years Ago
Visits: 21
wires (2/2/2014)
One thing to think about if you plan to use the latest version of SketchUp. 3DXchange only supports SketchUp .skp files up to version 8. In order to use models created with the new version you need to use the "Save As" option under "File" and select Sketchup version 8 from the drop down list. Thanks for that Wires, I'm using 3DXchange 4 pro, am I right to assume SketchUp V8 will be okay with that.:)
Posted 11 Years Ago
Posts: 5.7K,
Heatseeker
Heatseeker
Posted 11 Years Ago
Visits: 21
planetstardragon (2/1/2014) Hi Heatseeker,
Welcome to the forum :)
It would be worth if only if you had 3Dxchange - which is the software used to import/convert 3rd party models for iclone. Otherwise iclone alone won't be able to import anything beyond it's own proprietary formats.
Sketchup isn't so hard to learn to make simple stuff - it's not to say that you can't build more complex structures with it also - ie built to scale / spec with extreme detail - but for basic nice iclone models for filming it's fairly simple / straightforward.
Cheers!
Hi planetstardragon,thanks for your help. I do have 3DXchange so I will probably have a go with SketchUp. Thanks again for your help and advice. :)
planetstardragon
planetstardragon
Posted 11 Years Ago
Posts: 11.5K,
Visits: 46.0K
Hi Heatseeker, Welcome to the forum :) It would be worth if only if you had 3Dxchange - which is the software used to import/convert 3rd party models for iclone. Otherwise iclone alone won't be able to import anything beyond it's own proprietary formats. Sketchup isn't so hard to learn to make simple stuff - it's not to say that you can't build more complex structures with it also - ie built to scale / spec with extreme detail - but for basic nice iclone models for filming it's fairly simple / straightforward. Cheers!
Heatseeker
Heatseeker
Posted 11 Years Ago
Visits: 21
Hi, I'm wondering if it's worthwhile downloading SketchUp Make to use with iClone4. It's something else to learn and I've read that the download could be 'Iffy'. :unsure: Any ideas would be great, thanks in advance.:)
