planetstardragon (2/1/2014)
Hi Heatseeker,
Welcome to the forum :)
It would be worth if only if you had 3Dxchange - which is the software used to import/convert 3rd party models for iclone. Otherwise iclone alone won't be able to import anything beyond it's own proprietary formats.
Sketchup isn't so hard to learn to make simple stuff - it's not to say that you can't build more complex structures with it also - ie built to scale / spec with extreme detail - but for basic nice iclone models for filming it's fairly simple / straightforward.
Cheers!
Hi planetstardragon,thanks for your help. I do have 3DXchange so I will probably have a go with SketchUp.
Thanks again for your help and advice. :)
