8 Core CPU running at 100% with Iclone only
Posted By FreddyKrueger 12 Years Ago
planetstardragon
planetstardragon
Posted 12 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
you can never be too prepared for what may come in the next iclone upgrade! :alien:
"To define Tao is to defile it" - Lao Tzu
planetstardragon
planetstardragon
Posted 12 Years Ago
FreddyKrueger
FreddyKrueger
Posted 12 Years Ago
Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)
Posts: 97, Visits: 468
If you hang in there for a month or two you will see prices drop on the 7970's. I am interested to know how Iclone works with 770 or 780. I understand that these cards are probably too much for Iclone, however, when working in 64 bit every little thing helps.
Alienware 15, i7 4710hq, GTX 970m, 16gb ram, 4k display, 1.5TB SSD raid.
planetstardragon
planetstardragon
Posted 12 Years Ago
i'm contemplating a gtx 760 gamer twin frozer - but really want a gtx 770 lightning - i'm hearing the 7970 is blowing away the 760 - it's also about 50 bucks more. - but then I'm not sure if that was vs 760 regular ...or gamer tf edition which is clocked higher. The gtx 690 is the fastest at the moment.
FreddyKrueger
FreddyKrueger
Posted 12 Years Ago
w7000 works great in IC. It runs on par with gtx680 as far as my test scene goes. No CPU chugging either. I know its a pricy card, and if there are any pros out there using it, it may be worth it.
Anyone try the new gtx7xx series yet?
FreddyKrueger
FreddyKrueger
Posted 12 Years Ago
I did some more research on the firepro cards. I use my firepro 5900 for photoshop, premiere, after effects. 30-bit certainly helps with pro applications. Its kind of crazy how important certain things are to a professional composition. For instance, how many of you calibrate your monitors? Thats really the only way to get close to working with what you truly see. Another question to look into as well is how many peeps know just what percentage of RGB their monitors run? What percentage of NTSC? To most people with Iclone that may not matter, but if you are trying to put up something more professional out of Iclone (which can be done easily), then things like this do play a big role.
As far as firepro cards go, I looked into how they compare to gaming cards. Apparently the new Wxxx versions are doing quite well. W7000 is on par with 7870 for gaming, while w9000 is on par with 7970. This is actually pretty freaking awesome since Iclone certainly takes advantage of a gaming card vs. a workstation card. If you use pro programs such as Adobe, Autodesk etc... then this was actually a pleasant surprise. I think I may go, after all this bitching and moaning about differet cards, with w7000 and try it out. If it works good with IC, then we are in business.
DELETED2
DELETED2
Posted 12 Years Ago
Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)
Group: Banned Members
Last Active: 10 Years Ago
Posts: 2.4K, Visits: 6.1K
A couple of years ago if you recall I had a more basic nVidea and I literally melted its spindle so the fan crunched in its housing rendering in iClone.
Laughably when I took it back to the shop the sales assistant (Some kid) asked me as he prepared to argue replacing it, "What software did you use it for?"
!!!HUH!!!
When I told him he took the bits of card away to his superior commenting, "I'm not sure if you should have used it for that. I'll just go and speak to my manager!" :D
I felt like saying.
1. "Would you like me to show you what my Boot can be used for?" :w00t:
2. Does it make better Custard?
3. Would you like to buy it as a superior brain to the one youre evidently not using?
hgagne
hgagne
Posted 12 Years Ago
Posts: 90, Visits: 441
I've run into some of the issues noted here since IC4.x ... for example, random application crash when clicking any of the Color Picker tools, 100% CPU spike, frame rate drop, etc.
As with others who have replied, keeping my workstation up-to-date with the latest security updates and application patches is always a risk; so as to avoid such "time vampires", I've been freezing the machine state when I'm working on a revenue-related project.
When I am ready to update, I take a day to review product Release Notes - most notably nVidia and Microsoft Updates descriptions as they tend to be the frequent stability offenders.  For example, the current nVidia Release Notes highlight a few of the problems noted here:
http://us.download.nvidia.com/Windows/Quadro_Certified/320.49/320.49-win8-win7-quadro-tesla-notebook-release-notes.pdf
Cheers,
__________________________________________________________________
DELL Precision T7500 & Precision M6600
Dual Quad Core XEON 2.13 GHz, 12 GB RAM, 1 TB HDD's
nVidia Quadro 5000 (2.5GB RAM), Driver 320.49 (2013.07.03)
Windows 7 Ultimate (64bit)
Dual 22" LCD Monitors
iClone 5.5 Pro, 3DXchange 5.5 Pipeline, CrazyTalk & Animator Pro
Autodesk Entertainment Creation Suite 2014
Adobe Production Premium CS6
planetstardragon
planetstardragon
Posted 12 Years Ago
you may want to double check me on that though....for all I know the real time playing in iclone vs the actual rendering of the video may be different functions, but I do know the video card is more important than the cpu when it comes to Iclone performance. - Ie you can watch it play fast in real time, but when it comes to rendering, it can get as slow as molasses sliding uphill in mid winter ...on ice!! lol :)
FreddyKrueger
FreddyKrueger
Posted 12 Years Ago
planetstardragon (7/21/2013)
as far as I know
the gpu plays a major role in rendering
the ram takes the stress in textures and models.
the cpu takes the stress with videos and physics.
not sure what takes the stress in particles.
Good to know. In realtime rendering GPU plays a major role, that I know, but when it came to final rendering I thought CPU had somewhat or a role, but I was wrong. Either way, I tried a 7950 oc'd to 7970 specs and the rendering was great (speed wise, about 8 min and change for 1000 frame uncompressed render 1080p). So, either 7950 or 7970 will net you some great results. I did use 7850 a while ago and it was decent, it lagged a bit on bigger stuff, but was still a champ. So a nice cheaper alternatives are out there, and since RL hasn't updated their list for the 7xxx series or GTX 6xx, maybe it would be a good idea to get a project set up and have people with different cards test it and post the results???
